Page 1 of 3
v2.2.4 is out
Posted: 22 Oct 2016 03:26
Dear users, new Z-Way v2.2.4 is out
This new release as usually conatains a lot of fixes and new feaures.
New features:
- Postfix new features:
- a lot of changes in internal postfix logic
- new configuration possibilities:
- change device name, icon, hide or deactivate device, suppress device creation, change configuration or CC data
- add postfix error messages, postfix.json updated
- add expertconfig and api ExpertConfigGet + ExperConfigUpdate
- api's Postfix, PostfixUpdate, PostfixGet, PostfixRemove, PostfixAdd added
- ZAutomation API:
- allow also req type object as post object in login
- fix reload of initial getFirstLoginInfo call, add showWelcome entry - affecting (rebootBox, setLogin)
- pull request #342 and #372
- update main.js (//--- Load 3d-party dependencies) for HomeGear support
- Western Digital & Windows builds refreshed
- Instanciating controlled CCs based on NIF and on ZDDX selection (allows early binding on controlled CCs)
- Controlled CCs marked as Secure on first secure command with that class
- New DH bootloaderCRC and firmwareCRC to identify Z-Wave chip bootloader and firmware
- New controller.data.outgoingPacket and controller.data.incomingPacket for sniffer tool. Now you can see all packets in and out!
- Added callbacks to zway_device_send_nop(). API changed!
Modules:
- TamperAutoOff: workaround for devices that don't deactivate tamper sensor
- RoundRobinScenes: new param added in config
- LightMotionRockerAutocontrol: some bug fixes and improvements
- Z-Wave binding:
- Timing statistics changed according to new IMA data
- Added support for new bootloader and OTW to 6.70 SDK
- new sensortypes, seismic, acceleration x, y and z added
- IfThen: add Thermostat, SensorMultilevel support
- BindDevices: add thermostat support, change name to Association
- Notification: descriptions adjusted
- AutoLock: pull request #319
Documentation:
- Major Z-Way API (CC and FC) docs update, new PDF published on github
Fixes:
- Z-Wave-Me/zwave-smarthome #190
- ZWave module:
- Fixed Communication statistics wrong timestamp
- Fixed non-working blind stop command
- Fix for: Second Z-Wave module not generate a widgets #369
- bugfix: cannot read data of undefined / null (incomingPacket)
- RemoteAccess: bugfix: wrong ID after changing real ZBW ID.
- ScheduledScene: fixed bug after adding locks to the list of actions
- Backup Profiles.xml + notes.log added, Rules.xml removed
- UserCode hasCode fix
- Fixed CRC16 creation due to CRC error and falsly turning all output to CRC16-encapsulated
- Fixed Security Network Key initialization and prevent from answering on Scheme Get after Secure Inclusion timeout if Z-Way is included
- To early resend of Nonce Get fixed
- Validation of UTF8 string added before storing in DH (solveds problems with Qubino interview not saved)
- Error handling on DevicesData XML save operation - bad data can not kill previous comlete file anymore
- WebSockets connection problems (too early connection fail was not calling onConnect/onError) and DNS Lookup hangs fixed
- Freq change response fixed
- Fix possible crash on free of NULL data holder strings
- Mongoose utils bug with double Content-Length fixed
- Fixed callback handler execution for Secure jobs (fixed too early remove of original jobs)
- Fixed AddNodeToNetwork and RemoveNodeFromNetwork callback problems.
- According to Sigma any inclusion controller (means isPrimary == TRUE) should initiate secure interview. SecureInterviewAsInclusionController added to Defaults.xml
- After becoming SIS we will assume we can speak securely with other devices
Re: v2.2.4 is out
Posted: 24 Oct 2016 09:50
by ronie
Small supplement:
Changes of ExpertUI 1.1.0 and Changes of Smart Home UI 1.5.0 you could found in their project README.md's.
Re: v2.2.4 is out
Posted: 24 Oct 2016 16:07
by freeman
"Major Z-Way API (CC and FC) docs update, new PDF published on github"
Could you provide link?
Re: v2.2.4 is out
Posted: 24 Oct 2016 16:30
by pz1
Re: v2.2.4 is out: How do I change the element icon
Posted: 26 Oct 2016 10:14
by pz1
How/Where do I change the icon for this element? In some earlier rc's there was a non working function. Now (v2.2.4 final) I see nothing.
Re: v2.2.4 is out
Posted: 26 Oct 2016 18:59
by marco
Anybody know why Reorganization is not active?
Posted: 28 Oct 2016 08:56
by ronie
The formatting was a bit unfortunate. These are changes related to Postfix logic.
Yes, as you saw on earlier rc's of this version we're working on this functionality but we've added it more for look and feel tests first. It wasn't ready till v2.2.4. We're optimistic that we could put it into next releases.
Re: v2.2.4 is out
Posted: 28 Oct 2016 08:59
by ronie
marco wrote:Anybody know why Reorganization is not active?
Thats still broken at the moment and in progress. We've decided to grey it out instead of hiding it completely.
Posted: 28 Oct 2016 09:43
by pz1
ronie wrote:It wasn't ready till v2.2.4. We're optimistic that we could put it into next releases.
Thanks, this is helpful. At least I know now my system works as expected.
I quess that I must interpret some of the points of the release notes as preparations in the background. Just like the zniffer.html that sits in the htdocs/expert/app/views/installer branche, but is not yet available via the EUI ?
Re: v2.2.4 is out
Posted: 30 Oct 2016 06:14
by pierre2302
Hello
Since I made the update Zway I am unable to configure my devices.
Whenever I set a new value in the settings (eg 5), the value stored in the device reappears and I get the message "Value Was changed to 240 but not Stored in device yet."
