Easiest way to move the expert-ui-device names to smarthome-UI
klaasjoerg
Post by klaasjoerg »
Hi, for some reason, that I don't really understand, all my indivdual device-names in smarthome where reverted to standard names.
I have nearly 100 physival zwave devices (mainly fibaro and aeon sensors, switches, dimmers etc.). see first screenshot.
smarthome-ui
smarthome-ui
Luckily (and Interestingly) the device-names in expert-UI are still present. (see second screenshot)
Is there an easy way to let the smarthome-UI take over this as a default, instead of the cryptic device-names?
I would like to avoid having to edit all of my currently 425 vdevices.
Ideas?
expert-ui
expert-ui
ss 1.png (324.83 KiB) Viewed 4302 times
klaasjoerg
Re: Easiest way to move the expert-ui-device names to smarthome-UI
Since no easy way found, I manually edited the hundreds of devices from the scratch. Seems that changing postfix parameters crashed/removed my smarthome-ui-names/Definitions....
Spacerat
Post by Spacerat »
klaasjoerg wrote:
07 Jan 2018 22:02
I had the same issue:
http://forum.z-wave.me/viewtopic.php?f=3420&t=25536
In my case even some devices were missing...
I hope the next update will not break it again.
