question about entries in Analytics - ZnifferHistory
I have different actors, that provides always 4-5 times the same values. This may be an duplication error in ZnifferHistory,
but I also see in Analytics - Statistics a lot of Back off frames.
Transmissions vs Back-Offs 11:54
Sent frames: 6035
Back off frames: 2220
2018-04-18 13:13:29 40 1 - -72 dBm - C Multilevel Sensor Report (01, 22, 02, 10)
I assume that this may be caused by the transmitions from this device?!
It´s a Fibaro smoke sensor FGSD-002 where i disabled all functions except temperatur. So far it worked and I only get the
temperatur report and just this device in Z-Way.
Any idea?
Nico
Many duplicatet entries
- index.png (10 KiB) Viewed 2840 times
Re: Many duplicatet entries
I used extra hardware ZNIFFER and could see that there are many retransmissions as this device has no direct
connection to controller, so packets are often routed through 2-3 hops.
Changed controller position and now I´m fine.
