Rule still works after pausing or deleting it
woem
Post by woem » 02 Dec 2019 10:57
I run a Razberry (ZMEERAZ2; ver 3.0.1) with four motion sensors (Neo Coolcam motion with temperature) and a siren (Neo Coolcam as well). The sensors and the siren work perfectly well.
I use the IP:8083 frontend for configuration.
In order to have a basic burglar alarm, I generated a simple rule in the „rules“ section of the automation tab: When motion ist detected -> turn alarm on. That works perfectly well. BUT: When I pause the rule, it is still effective and the alarm starts, when motion is detected. Even if I delete the rule, it is still effective. So the burglar alarm is always on, even when I am home and that is …. a little annoying😉
The only way to stop it is to exclude the sensors/siren and include again. I have tried to reset everything to factory defaults and reinstall the Razberry, but that didn’t help: After generating a new rule and pausing or deleting it, it is still effective.
What am I missing here?
Thanks for your help!
Andreas
Re: Rule still works after pausing or deleting it
Post by PoltoS » 02 Dec 2019 12:15
This bug fixed in the new v3.0.2
Btw on v3.0.1 Z-Way restart helps
woem
Post by woem » 02 Dec 2019 13:43
Works like a charm now - thank you very much!!
Andreas
