Zigbee USB ?
DesT
Zigbee USB ?
Post by DesT »
Anyone knows if it's possible to add something on the raspberry to handle Zigbee? currently using the Razberry pro 7.
Re: Zigbee USB ?
Very soon Z-Station. Or mPCIe
jens_s
Re: Zigbee USB ?
Post by jens_s »
Are there any news, when Z-Station will be finally available?
Re: Zigbee USB ?
Just started sales from our Swiss facility. In two-three weeks on Amazon US and DE. For now you can order it from https://smartsd.ch/z-station-usb-adapto ... hread-ble/
michap
Contact:
Re: Zigbee USB ?
Post by michap »
Have ordered one at Amazon - it is available in US and Germany.
Osorkon
Contact:
Re: Zigbee USB ?
Post by Osorkon »
I receive the Z-Station today.
Z-Wave is working fine. With Z-Way Server and Z-Wave JS UI as well.
Bildschirmfoto 2024-04-16 um 23.45.20.png (65.12 KiB) Viewed 863 times
But the Zigbee part I cann't become to work. Not with ZHA, ZigBee2MQTT and also not with the Z-Way Server (ZigBee App)
Z-Wave is running on the serial Port
/dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_012B7AE7-if00-port0
Respectively
/dev/ttyUSB0
Zigbee configuration looks like this:
adapter: ezsp
baudrate: 115200
port: /dev/ttyUSB1
I tried also the port /dev/ttyUSB0
But always the same. Zigbee doesn’t wont to start?!
ZHA:
Bildschirmfoto 2024-04-16 um 23.32.07.png (83.45 KiB) Viewed 863 times
Bildschirmfoto 2024-04-16 um 23.32.39.png (50.16 KiB) Viewed 863 times
Bildschirmfoto 2024-04-16 um 23.33.10.png (16.32 KiB) Viewed 863 times
ZigBee2MQTT:
Bildschirmfoto 2024-04-16 um 23.35.02.png (324.74 KiB) Viewed 863 times
Any Ideas what is going wrong?
EDIT: How do I find out which firmware is installed?
I tried the the Z-Wave.me Tools -> ZigBee Tool for Windows
But it looks like the Windows Zip ist the same like the linux. Respectively both are for Linux?!
Running
zme_open_thread info -d COM9
I get
Reset protocol fail
Running
zme_ble info -d COM9
Oppening port			...................			OK
	FIRMWARE:
		GENERIC Ble adapter
Close port				...................			OK
Osorkon
Contact:
Re: Zigbee USB ?
Post by Osorkon »
Nobody an idea what is going wrong?! @PoltoS
How I can check which firmware ist installed?
What firmware does the Z-Station come with?
Could it be that the Z-Station ist defective?
Shoud I send it back and order a new one?
lanbrown
Re: Zigbee USB ?
Post by lanbrown »
Osorkon wrote:
19 Apr 2024 14:44
A brand new product that most have not even touched. When you're one of the first, not many are going to be able to help when they have no experience at all with the new device.
Osorkon
Contact:
Re: Zigbee USB ?
Post by Osorkon »
The question was aimed more at PoltoS. Or is he not part of the z-wave.me team?
He should have been using the Z-Station already for a few weeks.
See GitHub.
lanbrown
Re: Zigbee USB ?
Post by lanbrown »
You should contact support directly for a quicker response.
