Z-Connector connexion problem
Try to download it again
May be your filesystem has been corrupted and Z-Connector files are not valid now. Try to download it again and install.
I've tried like 20 times and
I've tried like 20 times and downloaded a file of 10 bytes. to open all I get as damaged or corrupt.
Problem has been reported
Problem has been reported earlier this year: http://en.z-wave.me/content/problems-z- ... r-download
That's all I read the problem
That's all I read the problem. "This was problem with recently registered clients only. " No solution? Because no connection with it. I will always recently registered clients?
thanks
thanks
There was a problem with last 23 registered clients
Indeed, registration was not completed on ours side. Should be fixed now. We apologize
Z-Connector can't connect - Failed to Open Device
Similar issue.
Installed the Z-connector under Windows 7 - 64 bit as per instructions tried to connect the Z-Connector and get the error message: Failed to open device: Permission denied.
I am logged in as admin, tried all USB ports, using COM5, tried \.COM5, rebooted, reinstalled, signed up with a new User ID, downloaded certificates, turned off firewall, nothing helps. About to give up with Z-Wave Me. Any ideas?
Should be a Windows problem.
Should be a Windows problem. Do you have firewall that can block access to h/w? Can other s/w access same port?
was having this issue.
If you are running homeseer, or in my case openremote, close it. Apparently two programs cant access it at the same time.
