Is it possible to install the software Z-Connector into a DSL router, in a way to not use a PC..?
If it's possible, how do you do...?
Pierrot
Z-Connector with DSL router
Yes, it is! For now we have recipes for OpenWRT DSL routers...
... and their clones: DD-WRT and Oleg's firmware. The process of installations is described in two posts:OpenWRT & DD-WRTOleg's firmwareSince Z-Connector comes in open source, you can also compile Z-Connector for any other DSL router if you know how to build applications your model.We also have a solution for FritzBox, but it is not published yet.Don't forget to share your success stories!
When will the Fritz!Box
When will the Fritz!Box solution be published?
I'm using a 7170, could you
I'm using a 7170, could you send me the one that worked already?
