Cannot install on Linux
yannick
Post by yannick »
I'm trying to install the z-connector on a linux machine but when running the Run_Z-Agent.sh I get the following error:
./Run_Z-Agent.sh: line 5: ./z-agent: No such file or directory
What am I missing? I already tried copying the z-agent.exe from the windows dir and install mono but the problem still exists.
You need to enter to Unix folder and run make
z-agent.exe is for Windows. Compile the Unix version to use on Linux typing make in the Unix folder
yannick
compiled
Post by yannick »
Is there a compiled version I can download? If not, how do I compile this?
There are no pre-compiled version
Since it should depend on your Unix architecture. To compile z-agent open a terminal, go to Unix folder in the Z-Connector package and type make.
eligv
Post by eligv »
When compiling in Ubuntu linux and Raspbian the Z-Connector folder get the following error
Fatal error: openssl / ssl.h The file or directory does not exist
I tried to install it with sudo apt-get install lib and also gives the same error. Any idea?
Merry Christmas to all and happy new installation
Install libssl files
Please try
sudo apt-get install libssl-dev
