Pls share example code for switching on a schedule?
jonespm
Post by jonespm » 08 Aug 2014 23:24
I am pretty new to z-way - I've got my devices included, reporting their status correctly and responding to manual control through the UI. But now, despite many hours of trawling through the documentation, forums and the examples of code that I could find, I am really stuck trying to move to the next step: creating a simple heating schedule.
In principle it looks fairly simple: use something like cron to send a message to z-way to set a switch. But I just can't get past the basics of what sort of file to put where and what else do to with it.
Can you share any sample code or tips, please?
Thanks very much!
martinisonline
Re: Pls share example code for switching on a schedule?
Post by martinisonline » 09 Aug 2014 23:20
Hello jonespm,
i understand what you going trough because i found myself in the same situation a month ago.
A developer manual for beginners, accomplish with the actual "Z-Way Developers Documentation 1.7" would be very, very nice for starters like us! An "Hello world" example is hard (impossible) to find and you have to dig lots of forums/post to start to understand the logic behind our razberry!
I will explain what i did and maybe would help with your situation either.
Please note that probably this is not the correct way of doing it, but its a way that works for me with actual versions (1.7.2).
I created a folder inside "automation" folder and called it "myFiles".
Inside that folder i have 2 files:
- myZwave.js
- cron.js
The cron.js file is a very nice script made by Stefan Liebenberg that allows you to schedule events in JS like the actual crontab in linux. you can find it here:
https://github.com/StefanLiebenberg/cron.js/
The myZwave.js file contains my own code, including (but not only) some schedule events.
At start, it loads the cron.js file. Then i have my own code.
At the end, i use the "Load custom JavaScript file" module from automation UI to load my myZwave.js file automatically every time the system starts.
The load path of files are relative of automation/ folder.
As a simple examle of myZwave.js file could be(not tested):
executeFile("/myFiles/cron.js");
var Crontab = new Cron(); //instatiates the Cron module
//simple example of turn on a wallPlug at specific time automatically
        //runs every day, at 20h30m00sec
	Crontab.add( new Cron.Job( "0 30 20 * * *", function () {
                //get status of the switch. Change N and I, according to your actual config
		var status = zway.devices[N].instances[I].SwitchBinary.data.level.value;
		//if the swich is off, turn it on
		if(status==false){
			zway.devices[N].instances[I].SwitchBinary.Set(255);
	Crontab.start();
Please note that every time you do any change on myZwave.js file, you must restart the zway system:
sudo /etc/init.d/z-way-server restart
If you have any errors on the file, it will not be loaded, and you should pay attention on the logs of zway.
After an update of Zway system version, the folder myFiles may be deleted and you should create it again.
I believe that this is not the best method, so any other methods/comments would be appreciated.
BR,
pz1
Post by pz1 » 10 Aug 2014 09:40
martinisonline wrote: I created a folder inside "automation" folder and called it "myFiles".
Folder userModules inside the automation folder is intended for storing user code that should survive a version upgrade.
martinisonline
Post by martinisonline » 12 Aug 2014 01:34
good to know pz1. I will change my project accordingly.
BR,
LAN-Opfer
Post by LAN-Opfer » 17 Oct 2014 23:18
...could you pls explain, how to get the file "crone.js"?
Under https://github.com/StefanLiebenberg/cron.js/ I find a Directory named "cron.js". Inside there a 2 files with the Name "cron.js" - cron.js-master/lib/classes/cron.js and cron.js-master/src/cron.js
Which one is the right?
Uwe
Z-Way v2.0.1-rc18 on Raspberry Pi
martinisonline
Post by martinisonline » 28 Oct 2014 21:47
Hey LAN,
I´m not 100% sure, because im traveling, and im not right in front of my system. Nevertheless, i think i used the file in "cron.js / build /" named "cron.cc.js".
give a try with that file.
Dont forget that, any time you change anything in your script, you need to restart the zway system in order to the new code be loaded. Pay also attention in the log files to understand if something goes wrong.
LAN-Opfer
Post by LAN-Opfer » 31 Oct 2014 00:04
ok - now it works :-)
Under "Z-Way Home Automation UI" - "Preferences" - "Automation" I created a new module "Load custom JavaScript file". "File Name" I filled with "userModules/Heizung/myZwave.js".
I created "/opt/z-way-server/automation/userModules/Heizung/myZwave.js" with
executeFile("userModules/Heizung/cron.cc.js");
Crontab.add( new Cron.Job( "0 50 21 * * *", function () {
zway.devices[7].instances[0].commandClasses[67].Set(1,15);
Crontab.start();
I copied "cron.cc.js" in the Directory "/opt/z-way-server/automation/userModules/Heizung/"
Restart Z-Wave and at 21:50 throttles the heating at 15 ° C
Thanks for your help!!
Uwe
