V2.2.0 Users are left out in the cold :(
remoticz
Post by remoticz » 19 Dec 2015 14:03
V2.2.0 11-Dec-2015 23:44. Up till today no reponse to serious user problem reports
v2.1.1 raspi2
remoticz
Re: V2.2.0 Users are left out in the cold :(
Post by remoticz » 26 Dec 2015 20:55
It is two weeks now :(
v2.1.1 raspi2
IZON
Post by IZON » 31 Dec 2015 19:49
i update without Reading The forums and now I regerar it hard since my whole setup is useless. Nothing works any longer. It doesn't even make a difference if I downgrade nor do a complete reinstall.
Interview doesn't work anymore. Exclusion seems to work, yey!!!
rmmacias
Post by rmmacias » 01 Jan 2016 17:47
It happened to me today, but you can revert the situation by downgrading to previous version (v2.1.1) following next steps.
Connect from your browser through local LAN:
1. http://your_device's_ip_address:8084
2. Go to the Firmware Tab
3. Select "update to" (the second button)
4. In the text box next to the second button type "v2.1.1" (without the " character)
5. Click "Update" button
I tried and it worked but be sure you type v2.1.1 and not 2.1.1 for example.
I hope it helped
IZON
Post by IZON » 01 Jan 2016 19:45
Yes I've tried that. :/
Even a complete reinstall of 2.1.1
My license key field is also now empty. That's probably the main reason?
And how to retrieve that?
rmmacias
Post by rmmacias » 03 Jan 2016 12:14
I can't help as I don't use license key due to the fact that I have the RaZberry card and Raspberry Pi. Anyway, it doesn't seem the key is the problem as I have the same effects in version v.2.2.0. I have tried several ways to upgrade (also from command line) but always got the same bad result. So I'm still with v2.1.1 :-(
remoticz
Post by remoticz » 06 Jan 2016 15:16
Almost four weeks since release, and no response from developers on serious user problems :shock:
v2.1.1 raspi2
pz1
Post by pz1 » 06 Jan 2016 21:31
Just learned this week still is holidays in Russia. I guess they will return to their desks next week to resume answering to problems.
IZON
Post by IZON » 01 Mar 2016 20:39
Probably still holiday ^^
Plainsane
Post by Plainsane » 09 Mar 2016 05:12
IZON wrote:Probably still holiday ^^
Hahahahahahahah
