Pushover Notifications App
Zway424
Post by Zway424 » 23 Jan 2016 16:21
I have tried the new Pushover Notifications app and really like it, however I haven't found a way to receive notifications from just a single device or devices. I would like to be notified only when an alarm is triggered or switch has been toggled. I've tried several options and they don't seem to be working correctly. I add the z wave device I want to receive pushover notifications, however it keeps giving me pushover notifications for EVERY Zwave device. Has anyone successfully used this app to receive pushover notifications for a single device and not all of your z wave devices in your network?
Thanks!
philmehew
Re: Pushover Notifications App
Post by philmehew » 04 Feb 2016 22:58
I'm having exactly the same problem, all notifications are working fine (but very annoying), and I just want to be notified when a dummy switch is turned on or off due to a schedule..mostly so I can check that scheduling and notification are working every day because my schedule failed this morning.
nizaga
Post by nizaga » 07 Feb 2016 10:57
i am having exactly the same problem and yesterday i reported a bug problem using the SmartHome UI...
Nacho
philmehew
Post by philmehew » 11 Feb 2016 01:42
I managed to find the developer's email address over the weekend, and we had a couple of mails between us. He said he was putting up a new version a couple of days ago, but when I uninstall and re-install via the app store in z-way GUI it still comes up as v1.0.0 unfortunately..and now the developer has gone quiet...probably thinks I'm not clever enough to use his product.
Raymond_B
Post by Raymond_B » 11 Feb 2016 22:08
I am having the same issue as well.
golaonline
Post by golaonline » 14 Feb 2016 02:44
This is one of the ways I am able to find out so far, in case there is a need to send notification to iOS devices. I looked at the issue above, I think the module code needs a very small change to support notifications for the specific devices. I am able to make that change and did some basic tests and it seem to work ok.
Iceman
Post by Iceman » 08 Nov 2016 12:43
In the Apps list there are two Pushover apps: Pushover and Push-ME. I use Push-ME and works correctly with the If->Then app. It creates one button toggle for each notification channel or application.
Uninstall Pushover first.
kWave
Post by kWave » 15 Dec 2016 21:38
Is there any way to put Sensordata in a Push-Me Message?
10neWulf
Post by 10neWulf » 18 Dec 2016 09:42
This might be a bit too much effort, but you could set a condition switch on your sensor, and have it trigger an event to send via pushbullet (Push-ME)? (This would only work for Binary Sensors though)
I do the above with IFTTT instead of PushBullet and it works great - I have a lawn watering schedule (Condition Switch) which only triggers based on whether it will rain or has rained (Virtual Rain Sensor) on certain days of the week, and whether I have enabled the schedule (Dummy Device). When the condition switch gets triggered, it turns on the solenoid to water the lawn, and triggers a IFTTT notification so I know watering has started and ended.
I also have another condition switch set earlier in the day, which triggers a notification via IFTTT to tell everyone in the house if the lawn will be watered that night (to make sure there are no clothes on the clothesline that might get wet...)
Tim
kWave
Post by kWave » 18 Dec 2016 22:55
Hey, i made a little modification to my Pushover-Me index.js file:
Insert the following code after:
PushNotifier.prototype.sendMessage = function () {
    var self = this;
Insert this:
/*** B E G I N / MODIFIED CODE TO USE %(variable) TO INCLUDE VALUES OF VARIABLES *****/
    var parseMessageCode = function(input)
        var expression = /\%\(([0-9A-Za-z\.\-_'"\(\)\]\[]+)\)/
        var t_result = null;
        while(t_result = expression.exec(input) )
            var insertThis =  eval('(typeof('+t_result[1]+') != "undefined") ? ('+t_result[1]+') : insertThis = "*EMPTY_VALUE*";');
            input = input.replace(t_result[0], insertThis);
        //console.dir(input);
        return input;
    /*** E N D / MODIFIED CODE TO USE %(variable) TO INCLUDE VALUES OF VARIABLES *****/
Then go a few lines down to
message: self.message
and change to:
message: parseMessageCode(self.message)
Now you can add somethins like this to your Message Text:
Temperature has been changed to %(zway.devices[5].instances[0].commandClasses[67].data[1].setVal.value)°C !
