2.2.2 Update
diemue
2.2.2 Update
Post by diemue » 08 Apr 2016 18:00
After updating to 2.2.2 i can´t access "http://raspberrypi:8084/cgi-bin/main.cgi".
I get an error message "Webif is switched off. You can switch it on from Z-Way UI or box shell"
Access to "http://raspberrypi:8083/smarthome/#/dashboard" and "http://raspberrypi:8083/expert/#/" works.
Downgrading to 2.2.1 same problem.
With the original 2.2.1 installation it worked.
DomotikQuebec
Re: 2.2.2 Update
Post by DomotikQuebec » 08 Apr 2016 22:31
Mario Gravel
Domotik Quebec
bogr
Re: 2.2.2 Update
Post by bogr » 09 Apr 2016 00:51
didn't know there was a 2.2.2 release. Are there any release notes? Was this announced anywhere?
diemue
Re: 2.2.2 Update
Post by diemue » 09 Apr 2016 09:49
solution for the problem was post https://forum.z-wave.me/viewtopic.php?f ... 1&start=20
sudo sh -c "echo 900 > /opt/z-way-server/automation/storage/8084AccessTimeout-6b497208061ec7faae003cdd7f9a035e.json"
Re: 2.2.2 Update (updated)
Post by pz1 » 11 Apr 2016 13:53
Be reminded that this morning at around 10:00 a new release with version number 2.2.2 has been published.
Amongst others this fixes an issue with some appstore apps.
Also the online Changelog has been updated to v2.2.2.
diemue
Re: 2.2.2 Update
Post by diemue » 11 Apr 2016 15:46
Not the 2.2.2 update seems to be the problem.
If i go back to a working 2.2.1 (backup) installation and execute "sudo apt-get update && sudo apt-get dist-upgrade", i run into the "http://raspberrypi:8084/cgi-bin/main.cgi - WebIf" problem.
Re: 2.2.2 Update
Post by pz1 » 11 Apr 2016 17:31
diemue wrote:Not the 2.2.2 update seems to be the problem.
Then don't post in this thread, but start a new thread, or add to the other threads that have been opened about the WebIF problem
sja
Re: 2.2.2 Update
Post by sja » 12 Apr 2016 17:04
Shouldn't news like this be posted at the "Official Announcements" section? I subscribe thos as rss feed to get info on updates.
Sorry, I haven't read this carefully.
