Where are all the apps?
kandalf
Post by kandalf » 25 May 2016 14:06
Hello together,
i received my razberry module and install the ryzberry image. Then update it to 2.2.2.
Now i have 3 devices:
- Remote Control
- Fibaro Double Relais
- Fibaro Mulit Sensor
Now i want to configure a scene that the relais 1 switch to on when the Multi Sensor say actual Luminiscence is under 200 Lux.
Where can i use scenes or where are all the apps? I only have 24-hour app, if->then app, scheduler app an local weather app.
Please can somebody help me?
There ist an option to save a licence key? Is that necessary for the razberry software?
Thanks and best regards...
Raspberry PI with Z-Wave.me Board
2 x Fibaro Double Relay-Switch FGS 222
2 x Fibaro Shutter FGR 222
Fibaro Multi Sensor
Z-Wave.me RemoteControl
Mike Yeager
Re: Where are all the apps?
Post by Mike Yeager » 27 May 2016 00:16
In the Smart Home Automation UI, click on the little gear in the top menu bar and select "Apps". There are all kinds of goodies there to get you started. Look for some of the posts about how to set things up efficiently or you may find yourself redoing things quite a bit later...
silverhack
Post by silverhack » 28 May 2016 01:08
Also be aware that when you go to Apps, the default only shows 'Featured Apps' and you will need to adjust your filters or search to see the many other apps as well.
kandalf
Post by kandalf » 29 May 2016 19:54
Thank you very much, the problem was the filter. Now i see over 50 apps.
Thanks.
Fibaro Multi Sensor
