Module that sets config params
pz1
Re: Module that sets config params
Post by pz1 »
In response to your question on Github
Hi @pz1,
can send me the result of the following request for one of your stellaz thermostat?
http://YOUR_IP:8083/ZWaveAPI/Run/devices[***].instances[0].commandClasses[64]
*** node id of stellaz thermostat
Many thanks!
Patrick
Here are the results of a new device I installed a week ago:
{"name":"ThermostatMode","data":{"invalidateTime":1479992333,"updateTime":1479992334,"type":"empty","value":null,"supported":{"invalidateTime":1479992333,"updateTime":1479992334,"type":"bool","value":true},"version":{"invalidateTime":1479992334,"updateTime":1479992335,"type":"int","value":3},"security":{"invalidateTime":1479992333,"updateTime":1479992334,"type":"bool","value":false},"interviewDone":{"invalidateTime":1479992333,"updateTime":1479992339,"type":"bool","value":true},"interviewCounter":{"invalidateTime":1479992333,"updateTime":1479992337,"type":"int","value":9},"modemask":{"invalidateTime":1479992333,"updateTime":1479992338,"type":"int","value":-2147481597},"mode":{"invalidateTime":1480962600,"updateTime":1480962748,"type":"int","value":11},"0":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"empty","value":null,"modeName":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"string","value":"Off"}},"1":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"empty","value":null,"modeName":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"string","value":"Heat"}},"11":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"empty","value":null,"modeName":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"string","value":"Energy Save Heat"}},"31":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"empty","value":null,"modeName":{"invalidateTime":1479992337,"updateTime":1479992338,"type":"string","value":"Manufacturer Specific"}}},"id":64}
Provo
Post by Provo »
FYI, I created the module in question: https://forum.z-wave.me/viewtopic.php?f=3424&t=24402
doubledrat
Post by doubledrat »
I know this is ancient, but it's the first thing to come up on a google search, so I thought I would give the answer
(To find out for your device, go into the expert UI in chrome, fire up dev tools with f12 and look at the network tab. Make the change in the UI and you will see the URL to use come up in the network log)
http://zwave:8083/ZWave.zway/Run/devices[5].instances[0].commandClasses[112].Set(42,600,2)
topcatsss
Post by topcatsss »
did this ever get working??
This is a very old thread. Please be more specific or open a new one
