HTML GET Command on Sensor Event
cpramhofer
Post by cpramhofer » 24 Nov 2016 17:56
Hi Community!
i´m looking for a solution to perform a HTML Command on a trigger Event of my Fibaro Motionsensor.
concret i want to perform this HTML Command:
"http://192.168.xxx.xxx:8080/remote?action=MONON" each time my Fibaro FIBEFGMS-001-ZW5 5G 4-in-1 Multisensor detects motion. and 5 Minutes later i want to perform "http://192.168.xxx.xxx:8080/remote?action=MONOFF"
any ideas how to get such a setup run?
kind regards
Christoph
pah111kg
Re: HTML GET Command on Sensor Event
Post by pah111kg » 24 Nov 2016 21:53
Have a look at "HTTP Device" (preinstalled). You could create a (dummy) switch binary, that performs a HTTP request.
Then you can combine the motion sensor with the "HTTP Device" by using a "Device- and Elementassociation".
I thing the delayed action after 5 minutes triggered by motion sensor isn't possible with preinstalled apps.
Regards,
Patrick
bogr
Post by bogr » 25 Nov 2016 00:48
You should be able to do this with the app "Delayed Action".
pah111kg
Post by pah111kg » 25 Nov 2016 09:00
I'm not sure but for "Delayed Action" only scenes work as a trigger and action. Or?
bogr
Post by bogr » 25 Nov 2016 20:53
yes, but you configure the scene to trigger a switch or dummy device or whatever you like. In your case just create a dummy or toggle which you configure to execute the command you like.
