[Android] Habitat - Open Beta test
Aegis
Re: [Android] Habitat - Open Beta test
Post by Aegis » 06 Jan 2018 14:15
Interesting!
I'll look into it.
Turns out that custom icons are a lot more complex than I assumed. I'd have to design some sort of mapper to correctly associate the device state with the correct icon.
I've created a landscape layout for the dashboard though! :)
Provo
Post by Provo » 11 Jan 2018 18:22
There is a slight inconvenience/annoyance with the GUI. When showing the device list in a room, the edit-button in the bottom right corner is covering the value of the bottom device. Considering that editing a room description is something one does very rarely, perhaps it would be better to remove that button and put that functionality elsewhere?
Aegis
Post by Aegis » 12 Jan 2018 00:21
Provo wrote:
11 Jan 2018 18:22
Good find! Ill figure out somewhere else to put the edit button. Thanks :)
fez
Post by fez » 04 Apr 2018 10:35
Hi. I just upgraded to Z-Way 2.3.7 and since then the app seem to have an issue to show the dashboard.
Aegis
Post by Aegis » 04 Apr 2018 10:58
fez wrote:
04 Apr 2018 10:35
Hi there and thanks for reporting the issue.
If possible, could you submit details of the problem on the github issue tracker? Do you get any error messages at all?
Aegis
Post by Aegis » 05 Apr 2018 18:38
The issue has now been fixed. New update published. Thanks for the report fez.
