raZberry Firmware Serial API UPgrade Impossible?(Solved)
Spirit78
Post by Spirit78 » 24 Feb 2017 22:11
I have being in contact with support and they ask me to upgrade the controller board to 5.07, Now I have 5.04, in the expert UI.
But it seems to be impossible to do an upgrade? It just spinns and reload the page after a while and the firmware is the same again?
Do I have to have a firmwarefile to do an upgrade, and if so, whre do I find that file?
//Andreas
diemue
Re: raZberry Firmware Serial API Version UPgrade Impossible?
Post by diemue » 25 Feb 2017 09:20
After the upgrade you must power off / power on the raspberry
Spirit78
Post by Spirit78 » 25 Feb 2017 12:44
Thanks for reply, but that doesn´t help
Have tried it several times....
If it would be possible, could I ask you to take a look at the picture and se if the same or someting else is written on the bottom of the controller info page on your z-way
SerialAPISetup Not Implemented.png (124.6 KiB) Viewed 5191 times
Spirit78
Post by Spirit78 » 25 Feb 2017 21:17
Finally i got 5.07 in.
After several powercycles and tries with the update. :D
Bastldd
Re: raZberry Firmware Serial API UPgrade Impossible?(Solved)
Post by Bastldd » 26 Feb 2017 10:01
Hey Spirit,
How did you do this? I have the same problem.
Bastl
AlphaX2
Post by AlphaX2 » 03 Mar 2017 19:14
Same here, how do you got it? Also the thing is, since the update it seems Razberry is not getting the wakeup call of battery devices, due to this my thermostats are not working as they should. :-/
Spirit78
Post by Spirit78 » 05 Mar 2017 21:48
I did:
1. sudo shutdown
2. Power Cycle
3. When started up whent in directly to Expert mode from WebUI and upgraded
I took about 3 times, so if it was the amount of tries or something else, I don´t know :roll:
But finally it worked
AlphaX2
Post by AlphaX2 » 05 Mar 2017 21:53
Okay I've got 5.07 but missing the SDK version in ExpertUI, but Firmware is officialy 5.07 now. Is the missing SDK a problem, at least it seems to work - but problem with thermostats still present. :?
Post by PoltoS » 06 Mar 2017 23:05
missing SDK is just a missing text mapping. dont worry
