ZWay crashing daily
jet11x
Re: ZWay crashing daily
Post by jet11x » 27 Jul 2017 23:41
Does clean mean delete this file?
Post by PoltoS » 28 Jul 2017 01:09
this will also help. Stop Z-Way, delete this file and restart
janjan
Post by janjan » 28 Jul 2017 21:13
how can i fix it on Popp Hub 2. it stops working once a month. Just repower helps. I can't reach the console for deleting notification.json.
Or is it not the same?
z-way 2.3.1
thanks
Post by PoltoS » 29 Jul 2017 03:09
It is certainly same. We are releasing an update for Popp Hub 2 next week - this will be fixed.
Post by PoltoS » 26 Oct 2017 01:43
If some of you still experience problems, please help us to locate the problem: viewtopic.php?f=3422&t=25592&start=10
cdogg76
Post by cdogg76 » 03 Nov 2017 22:00
Glad to see that this is continuing to be worked on in the other thread. Until this is fixed, I've got a cron that will run z-way-server every couple minutes (it does nothing it is currently running). Just a cheap watchdog. However, sometimes, after a crash, when z-way-server starts again, the z-wave bindings fail. The only way I know to recover from this is to power cycle the Raspberry Pi. I've had times when a restart isn't enough.
I'm assuming it has to do with the crash and bindings not being cleaned up properly. Is there something I can do to manually clear those bindings so that z-way-server can bind again? I'd like to somehow get the system to automatically recover.
Thanks!
Post by PoltoS » 04 Nov 2017 01:28
We need to see the log to understand the failure.
Mickyhaus
Post by Mickyhaus » 11 Nov 2017 11:07
Popp hub 2 is simply not stable at all!
Some apps are not working, GUI often stalls, and room climate control does not work.
I will no longer waste my time on such a buggy product.
Popp sometimes announces updates but nothing happens.
Bad user experience.
Post by PoltoS » 12 Nov 2017 01:24
We are about to release v2.3.6 next week. Please give it a chance. It should enhance a lot.
fundy
Post by fundy » 05 Dec 2017 22:55
I had these problems too with all the previous versions including 2.3.5. while on razberry running off SD card. Then I installed an ordinary usb/ssd drive as the razberry main system drive, ok made a clean zway 2.3.5. reinstall and since then the system has been totally stable for more than three weeks. No crashes at all. Before the crashes were daily effextivelly rendering the razberry unusable.
