Add default power consumption?
FredrikKarlsson
Post by FredrikKarlsson » 12 Jul 2017 09:26
Some Z-wave devices had power metering built in, but some don't. However, if a switch is ON and there are 27Watts worth of attached lamps, then it is not difficult to know what will be the current power consumption, right.
Is there any way to incorporate this information in a Z-way system?
Fredrik
Z-Wave Support
Re: Add default power consumption?
Post by Z-Wave Support » 13 Jul 2017 11:13
At the moment, there is no app in store.
Best regrads
Z-Wave Support
Post by PoltoS » 14 Jul 2017 02:54
@FredrikKarlsson but you can make yours ;) Select the power consumption, pick up a switch from the list and create new vDev of type meter that will multiply the ON time by the pre-defined power. Sounds nice app indeed.
