Yale lock always reported as unsecured (YRD220-ZW-619)
siulung
Post by siulung »
I have a new Yale touchscreen lock (YRD220-ZW-619) and paired it with my z-wave.me/razberry controller. I have a problem that no matter how I lock it (manually, timed auto relocking, or locking via z-wave), the status is always shown as unlocked.
These are the logs. Note that after the Door Lock Operation Set was delivered on 19:49:28.469, the response for Door Lock Operation Get at 19:49:29.259 has devices.10.instances.0.commandClasses.98.data.mode=0 which means "Door Unsecured" per http://z-wave.sigmadesigns.com/wp-conte ... on-A-M.pdf page 205. Even manually setting DoorLock to 255 ("Door Secured") via Expert UI => Expert Commands can't alter this to 255.
On the other hand, the lock is well aware that a remote lock operation occurred, as witnessed by incoming alarmType=24 of COMMAND_CLASS_ALARM, "RF Operate Lock" per https://github.com/openhab/openhab2-add ... .Codes.pdf
From these, it looks like to me that z-wave.me is working properly while the Yale lock RF module is at fault. Thoughts?
[2017-08-06 19:49:26.847] [core] --- ZWayVDev_zway_10-0-98 performCommand processing: {"0":"close","1":{}}
[2017-08-06 19:49:26.847] [zway] Adding job: Door Lock Operation Set
[2017-08-06 19:49:26.847] [zway] Adding job: Door Lock Operation Get
[2017-08-06 19:49:26.853] [zway] Node 10:0 CC Security: sending Nonce Get
[2017-08-06 19:49:26.853] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-08-06 19:49:26.853] [zway] Adding job: Nonce Get
[2017-08-06 19:49:26.853] [D] [zway] SETDATA devices.10.data.lastNonceGet = 271326471 (0x102c1d07)
[2017-08-06 19:49:26.864] [D] [zway] SENDING (cb 0xa7): ( 01 09 00 13 0A 02 98 40 05 A7 97 )
[2017-08-06 19:49:26.865] [D] [zway] RECEIVED ACK
[2017-08-06 19:49:26.869] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-08-06 19:49:26.869] [D] [zway] SENT ACK
[2017-08-06 19:49:26.869] [D] [zway] Delivered to Z-Wave stack
[2017-08-06 19:49:28.235] [D] [zway] RECEIVED: ( 01 07 00 13 A7 00 00 88 C4 )
[2017-08-06 19:49:28.241] [D] [zway] SENT ACK
[2017-08-06 19:49:28.241] [zway] Job 0x13 (Nonce Get): Delivered
[2017-08-06 19:49:28.241] [D] [zway] SendData Response with callback 0xa7 received: received by recipient
[2017-08-06 19:49:28.241] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2017-08-06 19:49:28.241] [D] [zway] Job 0x13 (Nonce Get): success
[2017-08-06 19:49:28.242] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-08-06 19:49:28.242] [D] [zway] SETDATA devices.10.data.lastNonceGet = 271326608 (0x102c1d90)
[2017-08-06 19:49:28.242] [zway] Removing job: Nonce Get
[2017-08-06 19:49:28.286] [D] [zway] RECEIVED: ( 01 10 00 04 00 0A 0A 98 80 6F 44 AE 50 34 96 5E 9C 46 )
[2017-08-06 19:49:28.286] [D] [zway] SENT ACK
[2017-08-06 19:49:28.287] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2017-08-06 19:49:28.287] [zway] Node 10:0 CC Security: received Nonce Report
[2017-08-06 19:49:28.287] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.rNonce = **********
[2017-08-06 19:49:28.287] [zway] Node 10:0 CC Security: Sending a secure message
[2017-08-06 19:49:28.287] [zway] Node 10:0 CC Security: sending encrypted packet: Door Lock Operation Set
[2017-08-06 19:49:28.289] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.toFollow = False
[2017-08-06 19:49:28.289] [D] [zway] SETDATA devices.10.data.lastNonceGet = Empty
[2017-08-06 19:49:28.289] [I] [zway] Adding job: Security, Door Lock Operation Set
[2017-08-06 19:49:28.289] [I] [zway] Node 10:0 CC Security: sending Nonce Get
[2017-08-06 19:49:28.289] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-08-06 19:49:28.289] [I] [zway] Adding job: Nonce Get
[2017-08-06 19:49:28.289] [D] [zway] SETDATA devices.10.data.lastNonceGet = 271326613 (0x102c1d95)
[2017-08-06 19:49:28.407] [D] [zway] SENDING (cb 0xa8): ( 01 1E 00 13 0A 17 98 81 40 0E 05 CE 45 2A DE 76 A1 FE 1E 32 6F EA 87 C9 5B 5D 78 51 03 05 A8 8D )
[2017-08-06 19:49:28.411] [D] [zway] RECEIVED ACK
[2017-08-06 19:49:28.415] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-08-06 19:49:28.415] [D] [zway] SENT ACK
[2017-08-06 19:49:28.415] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Response received - transfered to encapsulated jobs
[2017-08-06 19:49:28.415] [D] [zway] Delivered to Z-Wave stack
[2017-08-06 19:49:28.468] [D] [zway] RECEIVED: ( 01 07 00 13 A8 00 00 05 46 )
[2017-08-06 19:49:28.468] [D] [zway] SENT ACK
[2017-08-06 19:49:28.468] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Callback received - transfered to encapsulated jobs
[2017-08-06 19:49:28.468] [I] [zway] Job 0x13 (Door Lock Operation Set): Delivered
[2017-08-06 19:49:28.468] [D] [zway] SendData Response with callback 0xa8 received: received by recipient
[2017-08-06 19:49:28.468] [D] [zway] Job 0x13 (Door Lock Operation Set): success
[2017-08-06 19:49:28.468] [I] [zway] Removing job: Door Lock Operation Set
[2017-08-06 19:49:28.468] [I] [zway] Job 0x13 (Security, Door Lock Operation Set): Delivered
[2017-08-06 19:49:28.469] [D] [zway] SendData Response with callback 0xa8 received: received by recipient
[2017-08-06 19:49:28.469] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2017-08-06 19:49:28.469] [D] [zway] Job 0x13 (Security, Door Lock Operation Set): success
[2017-08-06 19:49:28.469] [I] [zway] Removing job: Security, Door Lock Operation Set
[2017-08-06 19:49:28.641] [D] [zway] SENDING (cb 0xa9): ( 01 09 00 13 0A 02 98 40 05 A9 99 )
[2017-08-06 19:49:28.642] [D] [zway] RECEIVED ACK
[2017-08-06 19:49:28.646] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-08-06 19:49:28.646] [D] [zway] SENT ACK
[2017-08-06 19:49:28.646] [D] [zway] Delivered to Z-Wave stack
[2017-08-06 19:49:28.693] [D] [zway] RECEIVED: ( 01 07 00 13 A9 00 00 04 46 )
[2017-08-06 19:49:28.693] [D] [zway] SENT ACK
[2017-08-06 19:49:28.693] [I] [zway] Job 0x13 (Nonce Get): Delivered
[2017-08-06 19:49:28.693] [D] [zway] SendData Response with callback 0xa9 received: received by recipient
[2017-08-06 19:49:28.693] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2017-08-06 19:49:28.693] [D] [zway] Job 0x13 (Nonce Get): success
[2017-08-06 19:49:28.693] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.rNonceAckWait = **********
[2017-08-06 19:49:28.693] [D] [zway] SETDATA devices.10.data.lastNonceGet = 271326653 (0x102c1dbd)
[2017-08-06 19:49:28.693] [I] [zway] Removing job: Nonce Get
[2017-08-06 19:49:28.743] [D] [zway] RECEIVED: ( 01 10 00 04 00 0A 0A 98 80 36 04 8F 2D 3A B2 DF 1D 29 )
[2017-08-06 19:49:28.743] [D] [zway] SENT ACK
[2017-08-06 19:49:28.744] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2017-08-06 19:49:28.744] [I] [zway] Node 10:0 CC Security: received Nonce Report
[2017-08-06 19:49:28.744] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.rNonce = **********
[2017-08-06 19:49:28.744] [I] [zway] Node 10:0 CC Security: Sending a secure message
[2017-08-06 19:49:28.744] [I] [zway] Node 10:0 CC Security: sending encrypted packet: Door Lock Operation Get
[2017-08-06 19:49:28.746] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.toFollow = False
[2017-08-06 19:49:28.747] [D] [zway] SETDATA devices.10.data.lastNonceGet = Empty
[2017-08-06 19:49:28.747] [I] [zway] Adding job: Security, Door Lock Operation Get
[2017-08-06 19:49:28.865] [D] [zway] SENDING (cb 0xaa): ( 01 1D 00 13 0A 16 98 81 5B 6C DC 3E E6 49 80 DD 97 5B 6C 36 D5 B0 23 42 BE 9A A6 73 05 AA 1F )
[2017-08-06 19:49:28.868] [D] [zway] RECEIVED ACK
[2017-08-06 19:49:28.872] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-08-06 19:49:28.872] [D] [zway] SENT ACK
[2017-08-06 19:49:28.872] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Response received - transfered to encapsulated jobs
[2017-08-06 19:49:28.872] [D] [zway] Delivered to Z-Wave stack
[2017-08-06 19:49:28.925] [D] [zway] RECEIVED: ( 01 07 00 13 AA 00 00 06 47 )
[2017-08-06 19:49:28.925] [D] [zway] SENT ACK
[2017-08-06 19:49:28.925] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Callback received - transfered to encapsulated jobs
[2017-08-06 19:49:28.925] [I] [zway] Job 0x13 (Door Lock Operation Get): Delivered
[2017-08-06 19:49:28.926] [D] [zway] SendData Response with callback 0xaa received: received by recipient
[2017-08-06 19:49:28.926] [D] [zway] Job 0x13 (Door Lock Operation Get): success
[2017-08-06 19:49:28.926] [I] [zway] Removing job: Door Lock Operation Get
[2017-08-06 19:49:28.926] [I] [zway] Job 0x13 (Security, Door Lock Operation Get): Delivered
[2017-08-06 19:49:28.926] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2017-08-06 19:49:28.926] [D] [zway] Job 0x13 (Security, Door Lock Operation Get): success
[2017-08-06 19:49:28.926] [I] [zway] Removing job: Security, Door Lock Operation Get
[2017-08-06 19:49:28.976] [D] [zway] RECEIVED: ( 01 08 00 04 00 0A 02 98 40 23 )
[2017-08-06 19:49:28.976] [D] [zway] SENT ACK
[2017-08-06 19:49:28.976] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2017-08-06 19:49:28.977] [I] [zway] Node 10:0 CC Security: sending Nonce Report
[2017-08-06 19:49:28.977] [I] [zway] Adding job: Nonce Report
[2017-08-06 19:49:29.097] [D] [zway] SENDING (cb 0xab): ( 01 11 00 13 0A 0A 98 80 1F B4 48 79 3C 2D 7E 13 05 AB AD )
[2017-08-06 19:49:29.100] [D] [zway] RECEIVED ACK
[2017-08-06 19:49:29.103] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-08-06 19:49:29.104] [D] [zway] SENT ACK
[2017-08-06 19:49:29.104] [D] [zway] Delivered to Z-Wave stack
[2017-08-06 19:49:29.198] [D] [zway] RECEIVED: ( 01 07 00 13 AB 00 00 0A 4A )
[2017-08-06 19:49:29.198] [D] [zway] SENT ACK
[2017-08-06 19:49:29.198] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-08-06 19:49:29.198] [D] [zway] SendData Response with callback 0xab received: received by recipient
[2017-08-06 19:49:29.198] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2017-08-06 19:49:29.198] [D] [zway] Job 0x13 (Nonce Report): success
[2017-08-06 19:49:29.199] [I] [zway] Removing job: Nonce Report
[2017-08-06 19:49:29.258] [D] [zway] RECEIVED: ( 01 21 00 04 00 0A 1B 98 81 EC F5 67 DF AF 67 97 31 43 20 4E AD 2C 4F 2B 4A 1F B5 AA 0E 11 33 84 B6 A9 28 )
[2017-08-06 19:49:29.258] [D] [zway] SENT ACK
[2017-08-06 19:49:29.258] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2017-08-06 19:49:29.258] [I] [zway] Node 10:0 CC Security: Received a secure message
[2017-08-06 19:49:29.259] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.firstPart = **********
[2017-08-06 19:49:29.259] [I] [zway] Node 10:0 CC Security: passing decrypted packet to application level: [ 62 03 00 00 02 fe fe ]
[2017-08-06 19:49:29.259] [D] [zway] SETDATA devices.10.instances.0.commandClasses.98.data.mode = 0 (0x00000000)
[2017-08-06 19:49:29.259] [D] [zway] SETDATA devices.10.instances.0.commandClasses.98.data.outsideMode = 0 (0x00000000)
[2017-08-06 19:49:29.259] [D] [zway] SETDATA devices.10.instances.0.commandClasses.98.data.insideMode = 0 (0x00000000)
[2017-08-06 19:49:29.259] [D] [zway] SETDATA devices.10.instances.0.commandClasses.98.data.condition = 2 (0x00000002)
[2017-08-06 19:49:29.260] [D] [zway] SETDATA devices.10.instances.0.commandClasses.98.data.lockMinutes = 254 (0x000000fe)
[2017-08-06 19:49:29.260] [D] [zway] SETDATA devices.10.instances.0.commandClasses.98.data.lockSeconds = 254 (0x000000fe)
[2017-08-06 19:49:29.616] [D] [zway] RECEIVED: ( 01 08 00 04 00 0A 02 98 40 23 )
[2017-08-06 19:49:29.616] [D] [zway] SENT ACK
[2017-08-06 19:49:29.616] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2017-08-06 19:49:29.622] [I] [zway] Node 10:0 CC Security: sending Nonce Report
[2017-08-06 19:49:29.623] [I] [zway] Adding job: Nonce Report
[2017-08-06 19:49:29.623] [D] [zway] SENDING (cb 0xac): ( 01 11 00 13 0A 0A 98 80 EF FD E6 AE 86 8A 7A 87 05 AC E7 )
[2017-08-06 19:49:29.627] [D] [zway] RECEIVED ACK
[2017-08-06 19:49:29.629] [D] [zway] RECEIVED: ( 01 04 01 13 01 E8 )
[2017-08-06 19:49:29.629] [D] [zway] SENT ACK
[2017-08-06 19:49:29.629] [D] [zway] Delivered to Z-Wave stack
[2017-08-06 19:49:29.739] [D] [zway] RECEIVED: ( 01 07 00 13 AC 00 00 0B 4C )
[2017-08-06 19:49:29.739] [D] [zway] SENT ACK
[2017-08-06 19:49:29.739] [I] [zway] Job 0x13 (Nonce Report): Delivered
[2017-08-06 19:49:29.740] [D] [zway] SendData Response with callback 0xac received: received by recipient
[2017-08-06 19:49:29.740] [D] [zway] SETDATA devices.10.data.lastSendInternal = **********
[2017-08-06 19:49:29.740] [D] [zway] Job 0x13 (Nonce Report): success
[2017-08-06 19:49:29.740] [I] [zway] Removing job: Nonce Report
[2017-08-06 19:49:29.800] [D] [zway] RECEIVED: ( 01 1E 00 04 00 0A 18 98 81 2B D3 6C C1 A7 BE 32 06 3A 2C 08 5F 26 EF 31 64 C3 85 8D 56 75 79 DA )
[2017-08-06 19:49:29.801] [D] [zway] SENT ACK
[2017-08-06 19:49:29.801] [D] [zway] SETDATA devices.10.data.lastReceived = 0 (0x00000000)
[2017-08-06 19:49:29.801] [I] [zway] Node 10:0 CC Security: Received a secure message
[2017-08-06 19:49:29.804] [D] [zway] SETDATA devices.10.instances.0.commandClasses.152.data.firstPart = **********
[2017-08-06 19:49:29.805] [I] [zway] Node 10:0 CC Security: passing decrypted packet to application level: [ 71 05 18 01 ]
[2017-08-06 19:49:29.805] [D] [zway] SETDATA devices.10.instances.0.commandClasses.113.data.V1event.alarmType = 24 (0x00000018)
[2017-08-06 19:49:29.805] [D] [zway] SETDATA devices.10.instances.0.commandClasses.113.data.V1event.level = 1 (0x00000001)
[2017-08-06 19:49:29.805] [D] [zway] SETDATA devices.10.instances.0.commandClasses.113.data.V1event = Empty
[2017-08-06 19:49:48.582] [D] [zway] Job 0x13: deleted from queue
