Missing items on Fibaro PIR G5 (Magic Eye)
RPJacobs
Post by RPJacobs » 21 Aug 2017 14:42
I've installed a FGMS-001 Application version 3.2 / SDK version 6.51.06 on my Razberry v2.3.5.
Schermafbeelding 2017-08-19 om 13.44.57.png (68.58 KiB) Viewed 5231 times
I can see all sensors in "Expert mode"
Schermafbeelding 2017-08-19 om 13.46.30.png (44.79 KiB) Viewed 5231 times
But only temperature and luminiscence show in my smarthome:
Schermafbeelding 2017-08-19 om 13.47.57.png (26.72 KiB) Viewed 5231 times
What am I doing wrong?
Re: Missing items on Fibaro PIR G5 (Magic Eye)
Post by PoltoS » 21 Aug 2017 23:23
Go to Devices -> Manage and check if there are "subdevices" under this #17. If not, we need to check why smart home engine do not get devices from the expert engine
RPJacobs
Post by RPJacobs » 22 Aug 2017 12:12
Only Temperature and Luminiscence show up as "sub-devices":
Schermafbeelding 2017-08-22 om 11.12.09.png (51.62 KiB) Viewed 5216 times
Any idea's?
klaasjoerg
Post by klaasjoerg » 22 Aug 2017 22:34
I have the same issue with some fibaro door/window sensors. I only get "tamper" sub-devices but no actuall contact/sensors/switches to see.
Interestingly this doesn't seem to be a problem on a naked, fresh re-installation of razberry with newest jessie version. But on my existing system with your 70 devices it simply doesn't work anymore sind 2.3.5. I also alread ex- and re-included several devices without luck....
timb
Post by timb » 22 Aug 2017 23:49
I have exactly the same issue with the same device (I have 2)
But I also cannot get these devices to Interview fully (they did in prior versions).
Missing is AssociationGroupInformation and Security
I am running v2.3.5
simonc
Post by simonc » 24 Aug 2017 01:23
same issue here, any ideas? I just bought one and I have the same behavior. Tried to reset everything and starting from scratch.
I have a Raspberry 3
Froschkoenig
Post by Froschkoenig » 24 Aug 2017 16:12
Same issue here. Interview is very slow and unstable. If completed after several attempts, only Luminescence and Temperature are available.
Firmware v2.3.5.
Thanks for help!
Z-Wave Support
Post by Z-Wave Support » 24 Aug 2017 16:56
This is a bug in Z-Way 2.3.5 :( . The Development is inform and will be fix it. A many device with Alarm Class are affected in this Version
Best regards
Z-Wave Support
simonc
Post by simonc » 24 Aug 2017 19:38
Hi Z_Wave-Support
do you think that this issue will be fixed shortly? like in a month or more?
Is the bug fixed in the new beta releases?
Z-Wave Support
Post by Z-Wave Support » 25 Aug 2017 09:31
I don't know. It is not in the current RC fixed.
Best regrads
Z-Wave Support
