Sonos App missing feature...
kandalf
Post by kandalf » 24 Nov 2017 12:00
i want to create a rule that control the volume from the sonos device.
For expample:
When volume is greater then 60 then set volume to 60.
With the sonos app it is possible to set the volume but i can't find the feature to read the actual volume setting.
Is it possible to add this feature to the sonos app?
Thanks.
Raspberry PI with Z-Wave.me Board
2 x Fibaro Double Relay-Switch FGS 222
2 x Fibaro Shutter FGR 222
Fibaro Multi Sensor
Z-Wave.me RemoteControl
Re: Sonos App missing feature...
Post by PoltoS » 24 Nov 2017 12:19
The device (dimmer) that corresponds to the volume should update its state when volume level is changed. You can use it in rules
