Alert after X minutes
asiobob
Post by asiobob » 07 Jan 2018 05:51
I have an AeonTec garage opener that shows as a door lock in z-way (it works well). It shows the status (locked/unlocked) correctly in z-way.
What I would like to achieve is to send a notification (email for now) if the door has been left open for more than X minutes.
Is there an App already that can help me with this, for example , if coniditon lasts for > 10 minutes then ACTION ?
I use to do this on the Vera UI5 and it worked well.
enbemokel
Re: Alert after X minutes
Post by enbemokel » 08 Jan 2018 14:19
I did something equal with a siren alarm. So, the garage opener can trigger a Dummy Device.
Then you may use the Timer Switch App.
asiobob
Post by asiobob » 19 Jan 2018 04:05
Thanks for this - the problem is I can't find a way for any of the apps (associate, if-then, logic rule) to capture the 'door unlock' event. If I could do this I could turn on a light or start a timer etc. Any ideas how to overcome this?
enbemokel
Post by enbemokel » 19 Jan 2018 18:10
Did you installed this App: "Trap events from Remotes and Sensors", not sure if it is necessary.
