Fibaro Poor Link
OneWorld
Fibaro Poor Link
Post by OneWorld » 22 Jan 2018 09:30
Hello
I`m using Razberry Controller + Raspberry 3 + Fibaro double switch 2. ( 868.4 ), (up to 50m outdoors up to 40m indoors))
My First double switch 2 is 5 meters from Razberry controller and my second double switch 2 is on my second floor only 15 meter from my Razberry Controller and 10 meter from my first double switch 2.
My second switch has very poor signal (most of the time don`t get command from Razberry controller).
Does the Razberry Controller automatic routed communication with the double switch 2 through other modules (repeaters) ?
Do I need to config it through expert configuration or change some parameter on the Fibaro double switch 2 ?
Can I increase the power signal (PowerLevel db) ?
