Unstable - crashes & wrong status from devices
benis
Post by benis » 05 Feb 2018 11:46
Hi all,
I have a Pi 2 with RaZberry thing on and running latest Z-Way software. I have to very annoying issues:
1.) The Z-way system just crashes from time to time, at least the web/app interface. I cannot access it and have to SSH to the Pi and reboot it. Then it works fine for a few days again. Being like this for a few months and happens 1-2 a week.
2.) I also use it for thermostat and last year it worked fine - but this year, sometimes the switch for the radiators (for heating, two radiators connected to one 2.3Kw z-wave switch) do not turn them off - but in the interface, it says off. So if I manually click on "off" - it turns off for real. I even replaced the switch a couple of days ago because I thought it was the switch, but no. Same issue with the new switch (different brand).
What can I do?
Thanks in advance!
Popp Wod
Re: Unstable - crashes & wrong status from devices
Post by Popp Wod » 09 Feb 2018 00:18
I have a Popp Server v1. So I usually have the same hardware.
Just to confirm, this happens to me as well since some weeks. I did not change or add any hardware. Some scenes if started by if=then e.g. „close shutters“ suddenly stopp after 6 shutters although it used to work with all 13 shutters before.
benis
Post by benis » 10 Feb 2018 05:44
I bought a Samsung Smartthings Hub V2 instead. No more mess.
