Fibaro double switch fgs223 problem
dvd2000
Post by dvd2000 » 26 Mar 2018 10:26
I have a problem with fibaro double switch fgs223:
With version 2.3.1 and older versions it work correctly.
With newer version (including 2.3.7) switching on/off from UI works, but in 80% of cases fail to report the switch state. (lights are off, but the UI "thinks" is on and viceversa)
If i use the physical switch the state in UI is reported correctly.
Revert back to 2.3.1 solve the problem
These are the timings of the switch:
7 Fibaro luci 09:24 30 100% 5 11 9 17 11 5 11 12 4 11 12 7 16 11 10 12 7 4 11 13
dvd2000
Re: Fibaro double switch fgs223 problem
Post by dvd2000 » 26 Mar 2018 15:10
Have done a reorganization under 2.3.1 and then upgraded to 2.3.7. Now seems to work better.
But in 2.3.7 if i open the reorganization window it freeze... tried different browser but nothing.
