Raspberry Stretch Support
temp
Post by temp » 03 Jun 2018 09:21
IS IT planned?
Muramat
Re: Raspberry Stretch Support
Post by Muramat » 04 Jun 2018 11:04
Dear all,
I just have a new RPI 3b+ and I cannot install Raspbian Jessie as it not supported, and I have problems running Zway. Any way to make it work? reading the forum seems it is not possible. Any solution?
thanks
Z-Wave Support
Post by Z-Wave Support » 04 Jun 2018 14:47
Please install the newest Raspian.
Install the newest version of Z-Way
and install the following patch:
wget -q -O - support.zwave.eu/libs | sudo bash
https://forum.z-wave.me/viewtopic.php?f ... ech#p72592
Best regards
z_Wave Support
temp
Post by temp » 05 Jun 2018 08:37
IT IS Not working for me....
añep
Post by añep » 07 Jun 2018 09:30
In new versions of raspbian, disabled bluethooth manually is neccesary:
echo "Disbled Bluethooth"
echo "dtoverlay=pi3-disable-bt" >> /boot/config.txt
echo "Remove Configuration Bluethooth Service"
update-rc.d hciuart remove
Due to problems with memory frequency in first boards Raspberry 3B+, rpi-update is neccesary:
apt-get update
apt-get dist-upgrade
rpi-update
I have a Raspberry Pi 3 B+ with v2.3.7 working successfully.
Regards.
Muramat
Post by Muramat » 08 Jun 2018 10:49
I have made everything possible but I still get:
at the installation of Zway
Stopping mongoose http server
[ ok ] Stopping mongoose (via systemctl): mongoose.service.
Adding mongoose to autostart
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_CTYPE = "UTF-8",
LANG = "en_GB.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("en_GB.UTF-8").
Start mongoose http server
[ ok ] Starting mongoose (via systemctl): mongoose.service.
ls: cannot access 'config/zddx/*.xml': No such file or directory
Usage: ./z-cfg-update <filename>
rm: cannot remove '/tmp/zway_install_inittab': No such file or directory
Starting z-way-server
Starting z-way-server: done.
Thank you for using RaZberry!
I the web application
09:43 | "Cannot start Z-Wave binding: Error: Bad data - communication failed"
Cannot instantiate module: MobileAppSupport: TypeError: Cannot read property 'table' of undefined"
Z-Wave Support
Post by Z-Wave Support » 08 Jun 2018 10:55
what for a controller do you use?
UZB or Razberry?
Best regards
Z-Wave Support
Muramat
Post by Muramat » 08 Jun 2018 12:59
Razberry
Gema
Post by Gema » 12 Jun 2018 09:42
I have a Raspberry Pi 3 B+ with v2.3.7 working more
 successfully.
hansch
Post by hansch » 13 Jun 2018 20:50
I have the same error ( pi3b+ and module 2:
[2018-06-13 18:01:54.784] [D] [zway] Opened device: /dev/ttyAMA0
[2018-06-13 18:01:54.784] [D] [zway] Worker thread successfully created
[2018-06-13 18:01:54.784] [D] [zway] Worker thread entry point
[2018-06-13 18:01:54.785] [zway] Adding job: Get controller info and supported function classes
[2018-06-13 18:01:54.794] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-06-13 18:01:54.996] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-06-13 18:01:54.996] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-06-13 18:01:55.197] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-06-13 18:01:55.198] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-06-13 18:01:55.399] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-06-13 18:01:55.399] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2018-06-13 18:01:55.399] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2018-06-13 18:01:55.399] [C] [zway] Get Serial API Capabilities returned zero.
[2018-06-13 18:01:55.399] [zway] Removing job: Get controller info and supported function classes
[2018-06-13 18:01:55.410] [D] [zway] Worker thread exit point
[2018-06-13 18:01:55.410] [D] [zway] Worker thread successfully finished
[2018-06-13 18:01:55.420] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2018-06-13 18:01:55.439] [core] Error: Bad data - communication failed
[2018-06-13 18:01:55.440] [core] Tried 5 times without success. Stopping tries.
[2018-06-13 18:01:55.441] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
When trying to use ExpertUI, it also start throwing errors and nothing is going to be displayed...
Any idea how to fix?
