Razberry boards fail to pair any device
Pawel Stavros
Post by Pawel Stavros » 10 Jul 2018 12:25
Hello everyone.
I am working on a project where we are using the Razberry board for the communication with several sensors. We have purchased 50 Razberries and I have paired every single device successfully. There are 2 boards though that behave differently than the others and I cannot pair any device (I have tried several different devices).
In the normal pairing procedure, when I start the pairing of the device, there is a red light on the Razberry board at the beginning, and when I trigger the device to be added, a green light blinks until the procedure concludes.
On the other hand, for these 2 problematic boards, the green light does not blink but instead, it is permanently on.
Have anyone else had similar issues? is this a software issue or a hardware issue??
Is there anything I should check in the log files or any configuration to try through the expert?
