Razberry Image and UZB not working
Posted: 14 Sep 2018 16:09
Hi all,
I just installed the Razberry Image provided by Z-Wave. The problem is, I can't connect to the internet, which normally should be straight forward. Neither Wifi, nor Ethernet is working.
Then I installed the classic Raspbian Image and after that installed the z-way-server using wget. It worked, but now I can't initialize the Z-Wave UZB Stick...
In the manual it is stated on p.14 I guess, that you have to pass the license key in the ExpertUI (there I'm constantly getting following error message: "Communication or binding error! Please login again or check system connectivity.") in the controller info. But there is no such window for registering or activating the UZB Stick.
Please help, I don't know what to do further...
Thanks in advance
Thanks in advance
