Cannot start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
MM30
Post by MM30 » 06 Oct 2018 20:05
I have start my z-way-server on a ubuntu machine the first time.
Then I get this error:
[2018-10-06 16:36:18.562] [core] ReferenceError: ZWaveBinding is not defined
[2018-10-06 16:36:18.563] [core] Tried 5 times without success. Stopping tries.
[2018-10-06 16:36:18.565] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
What should I do?
Thank you!
Popp Wod
Re: Cannot start Z-Wave binding: ReferenceError: ZWaveBinding is not defined
Post by Popp Wod » 24 Oct 2018 14:18
Several people have the same issue with their raspberries.
Have you been able to solve this?
Post by PoltoS » 28 Oct 2018 00:26
This means Open SSL or libarchive library mismatch
Run it from shell and check first 15 lines of output
