Manuel clock configuration - Israel TimeZone
OneWorld
Post by OneWorld » 07 Oct 2018 08:06
ZWAVEME on RASP3.
It`s really strange but under Management - Timezone I can`t find option for ISRAEL\JERUSALEM (GMT‎+3 ).
Where is the Manuel clock configuration?
Eagle
Re: Manuel clock configuration - Israel TimeZone
Post by Eagle » 07 Oct 2018 11:34
You can take several other iana timezones where GMT+3 is observed. For example the third one on the list, africa/addis ababa, is also a GMT+3 time zone.
OneWorld
Post by OneWorld » 07 Oct 2018 12:21
Hi thanks...
I get "Unable to load data" when I try to save new timezone " africa/addis ababa" why ?
There is no way to change the time\date manually?
Maybe the z-wave server Pulls the time from the RASP ?
It`s so complex operation to change clock?
Eagle
Post by Eagle » 08 Oct 2018 16:00
i dont know how to change the time and date manually.
normally you just set it to your timezone and save
what version are you running?
go to apps => active => 'Time zone and access from home network' and set it to africa/addis ababa and save.
if you get unable to load data, try to restart your zway server
OneWorld
Post by OneWorld » 08 Oct 2018 16:09
I make the timezone change from EXPERT mode .
But still time is not accurate.
Z-WAY 2.3.7
msambol
Post by msambol » 24 Oct 2018 00:02
In case this is still relevant:
ssh into the raspberry. User pi, default password is raspberry if you haven't changed it yet.
run the configuration program with
sudo raspi-config
from the menus choose 4, 2, Asia, Jerusalem
then Finish
Then there is no need to deal with timezone in the Z-way application.
OneWorld
Post by OneWorld » 27 Oct 2018 13:27
True!!
after restart . Everything ok
