Login error in 2.3.8
theforce
Post by theforce »
Hi!
I had hoped that 2.3.8 would have fixed the login issue mentioned here: https://github.com/Z-Wave-Me/zwave-smarthome/issues/242 .
The login issue is related to this issue: https://github.com/Z-Wave-Me/home-automation/issues/441 .
I can confirm that even though the release notes of 2.3.8 states:
"- Added libraries for Raspbian Stretch"
"- Fixed socket not being closed on peer disconnect"
I keep getting this error after opening a web socket. The error occurs every time after the web socket is closed, either normally or abnormally, i.e. if the host is down, non-existent or disconnects unexpectedly. As long as the web socket is connected there is no error, but as soon as the socket is closed the error occurs and Z-way must be restarted in order to login again.
Detailed instructions of how to reproduce the error can be found here: viewtopic.php?f=3419&t=22347&start=30#p69949 .
Please note that the error occurs regardless if the host is up or down, the problem occurs when the connection closes. It is also not necessary so specify the protocol-parameter in the sockets.websocket constructor.
I'm running Raspbian Stretch on my Raspberry Pi 3 Model B.
Hope you can fix this issue as soon as possible. When it is fixed I will release a Z-way plugin which can control LG WebOS TVs with web sockets.
/Mattias
brizz
Re: Login error in 2.3.8
Post by brizz »
Can confirm I'm also still experiencing this issue trying to implement a plugin that uses websockets. All fine until you disconnect - then auth. does not work. Was also hoping this would be fixed :(
If I'm remembering right, it's related to an older internal state of OpenSSL becoming mangled. Another thread here: viewtopic.php?f=3419&t=24524
