Page 3 of 4
Re: 2.3.8. - Binding Problem - No Devices
Posted: 01 Nov 2018 08:20
by Popp Wod
PoltoS wrote: ↑28 Oct 2018 12:31
Will ping today to check where it landed
Any update, Polto?
Is this related to the Linux version we are using? Or is this related to the image?
I never had any RC images installed. Just one additional Tool installed, called monit.
Why is there no answer of your support-team?
BR, Wod.
Posted: 01 Nov 2018 12:46
by michap
PoltoS found just now a solution for fixing.
I have tested and it is working fine:
Login into Shell, then execute:
cd /opt/z-way-server
rm libs/libarchive.so*
sudo apt-get install libarchive12
ln -s /usr/lib/arm-linux-gnueabihf/libarchive.so libs/libarchive.so.13
Restart the Popp Gateway, and all will be back.
Michael
Posted: 02 Nov 2018 09:42
by temp
Can anyone confirm this?
Posted: 03 Nov 2018 14:44
by kovi44
Dear all,
I'm running 2.3.7 on RPI3 - raspbian jassie. I did upgrade to 2.3.8 yesterday with no success. After the upgrade and reboot the z-way-server do not start at all. I try to start it manually but it stops with some errors. Then I just restore the backup of 2.3.7 (which is done automatically - just rename the previous one) and the 2.3.7 start again without any problem.
Do someone else got the same issue using the same distro and hw? Thanks
Posted: 03 Nov 2018 20:22
by michap
kovi44 wrote: ↑03 Nov 2018 14:44
This maybe another problem - please open a new topic, if other issue.
The current issue happen at "old" POPP Gateway (or any Pi with Wheezy) after updating to 2.3.8 - that no devices visible and a binding error will be shown.
The published fix is
ONLY for this case.
Recommendation is to upgrade the OS for older systems - if possible.
Michael
Posted: 04 Nov 2018 20:19
by optimizer
michap wrote: ↑01 Nov 2018 12:46
Michael
Thanks.
I can confirm that this fixed my controller issues (same as thread starter) after updating the RaZberry firmware to 2.3.8 from 2.3.6 (raspbian - wheezy).
/Tobbe
Posted: 05 Nov 2018 12:09
by Popp Wod
Version 2.3.8 has been retracted for Popp hub v.1 and is actually no longer available.
Posted: 06 Nov 2018 18:38
by temp
optimizer wrote: ↑04 Nov 2018 20:19
Michael
Thanks.
/Tobbe
You are using the razberry Board 2 Extension fit Raspberry???
Posted: 07 Nov 2018 00:28
by optimizer
temp wrote: ↑06 Nov 2018 18:38
Thanks.
/Tobbe
I'm using Razpberry board v1 plugged onto a Raspberry B GPIO. My z-wave controller hardware is from January 2014. Not sure I dare to update any more times now. Last time I updated, a year ago?, the webinterface and API was modified slightly and gave me some headache because I had to update all my control scripts (perl).
/T
Posted: 07 Nov 2018 18:23
by ronie
Hey guys,
please excuse the long absent ...
@michap thx for your time to investigate this issue and providing this fix as workaround.
As you already found out the problem is related to teh old Debian 7 (Jessie) on which your last Z-Way v2.3.7 was running.
I've prepared some receipes that will hopefully help to solve this issue:
Upgrade Raspbian Wheezy (Debian 7) to Jessie (Debian 8) to support Z-Way v2.3.8 (specially for Popp Hub 1)
Revert a Z-Way upgrade with help of the terminal
