[Solved] - UZB1 driver won't install, no access
Teza
Post by Teza » 27 Oct 2018 19:00
Just received an UZB1, and can't get it installed in win7.
Windows update find no driver for this unit.
Have downloaded the UZB driver from 2 different places, but only get the error:
Driver found, but an error occured, UZB - no access.
Have I received a bad unit?
Also, for the pricetag I am dissapointed to see that it is made of cheep plastic only.
Re: UZB1 won't install, no access
Post by PoltoS » 28 Oct 2018 00:16
It is the cheapest and smallest stick in the world.
With UZB driver you should get a com port. Do you see it?
Teza
Post by Teza » 28 Oct 2018 00:22
All I get is "unknown device", not able to install the driver.
"Driver found, but an error occured, UZB - no access"
Post by PoltoS » 28 Oct 2018 00:24
The driver on our site should suit Windows 7
Teza
Post by Teza » 28 Oct 2018 00:28
Have downloaded the driver today from z-wave.me and from the shop where I ordered it. Same problem with both drivers.
DriverVer=06/10/2013,0.0.4.0
Have also tried to install the driver manually without UBZ connected, and still get the message No access
Teza
Post by Teza » 28 Oct 2018 01:06
The two driver files were highlighted in green color, wich means their content were encrypted to secure data.
Right click on the driver folder => Properties => General Tab => Advanced
Remove the selection of "Encrypt contents to secure data"
Apply for subfolders and files.
Drivers will now install.
