Specify a fixed tty name for UZB1 on a specific USB port
Post by PoltoS » 07 Nov 2018 00:04
Sometimes you need to fix the tty name for your UZB1 on a specific port. Especially when you use similiar ACM devices on different ports.
This can be easily done using udev subsystem.
Plug your dongle and run (supposing it is called ttyACM0 right now):
# udevadm info -a -n /dev/ttyACM0 | grep {devpath} | head -n 1
ATTRS{devpath}=="1"
Use this value in the next line.
create a file /etc/udev/rules.d/99-acm-fix-tty-name.rules
SUBSYSTEM=="tty", ATTRS{devpath}=="1", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="ZWavePort1"
The last parameter specifies which additional name to use.
Re: Specify a fixed tty name for UZB1 on a specific USB port
Post by PoltoS » 07 Nov 2018 00:30
Just in case, to remotelly reconnect your USB device you can use
for i in /sys/bus/pci/drivers/[uoex]hci_hcd/*:*; do
[ -e "$i" ] || continue
echo "${i##*/}" > "${i%/*}/unbind"
echo "${i##*/}" > "${i%/*}/bind"
done
