aeotec multisensor 6 - device configuration missing
dirkh
Post by dirkh » 23 Nov 2018 10:32
I have several Aeotec Multisensor 6 EU, which acctually works fine.
Unfortunately, since zway 2.38 the device configuration page has been changed for several devices.
If I set the device description ("Select Device Description"), the dedicated settings were shown for the MultiSensor.
In example, "Nº 4 - Enable/disable the function of motion sensor." or "Nº 5 - Motion Detection" with all possible values.
If I change (or select) the device description in the new version, there is only "Wakeup time, seconds ... " remaining.
All other possible settigns vanished.
Also I noticed that device "FGRM-222" (Fibaro Roller Shutter) is not in the list anymore
Any Idea/Solution ??? Or is this just new feature.
Dirk
Re: aeotec multisensor 6 - device configuration missing
Post by PoltoS » 04 Dec 2018 00:31
We are now taking the database from the Alliance. You can take the zddx you need from the old distro and run UpdateXMLs.py in the folder
