I know that this subject have been mentioned over and over again. I'm trying to figure out weather there is some problem with the board / my rasberry or the software. This is my first IoT project and I have very little knowledge about Linux operating system.
I have bought brand new Raspberry Pi 3 and RaZbery hardware. I have installed everything with documentation, razbian from image and z-way using
wget -q -O razberry.z-wave.me/install | sudo bash
System I'm using is:
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
VERSION_ID="9"
VERSION="9 (stretch)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
v2.3.8
speed 115200 baud; line = 0;
min = 1; time = 0;
-brkint -icrnl -imaxbel
-opost -onlcr
-isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
[2018-11-24 21:06:56.348] [D] [zway] Opened device: /dev/ttyAMA0
[2018-11-24 21:06:56.349] [D] [zway] Worker thread successfully created
[2018-11-24 21:06:56.349] [D] [zway] Worker thread entry point
[2018-11-24 21:06:56.349] [I] [zway] Adding job: Get controller info and supported function classes
[2018-11-24 21:06:56.359] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-11-24 21:06:56.560] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-11-24 21:06:56.560] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-11-24 21:06:56.762] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-11-24 21:06:56.762] [D] [zway] SENDING: ( 01 03 00 07 FB )
[2018-11-24 21:06:56.963] [I] [zway] Job 0x07 (Get controller info and supported function classes): No ACK received before timeout
[2018-11-24 21:06:56.963] [W] [zway] Job 0x07 (Get controller info and supported function classes) dropped: too many resends
[2018-11-24 21:06:56.963] [D] [zway] Job 0x07 (Get controller info and supported function classes): fail
[2018-11-24 21:06:56.963] [C] [zway] Get Serial API Capabilities returned zero.
[2018-11-24 21:06:56.963] [I] [zway] Removing job: Get controller info and supported function classes
[2018-11-24 21:06:56.973] [D] [zway] Worker thread exit point
[2018-11-24 21:06:56.974] [D] [zway] Worker thread successfully finished
[2018-11-24 21:06:56.984] [E] [zway] SaveData will not save data since it wasn't loaded. This is to prevent data loss.
[2018-11-24 21:06:57.002] [I] [core] Error: Bad data - communication failed
[2018-11-24 21:06:57.003] [I] [core] Tried 5 times without success. Stopping tries.
[2018-11-24 21:06:57.006] [I] [core] Notification: critical (z-wave): Cannot start Z-Wave binding: Error: Bad data - communication failed
Can someone please give me some directions what to do? How can i debug this thing deeper? I'm trying to spin it up for last 3 days.
I was able to write some JavaScript to open the com port and write something to the device, but no answer.
