Unable to update firmware / install apps / update apps
vafen
Post by vafen » 18 Dec 2018 07:41
Hi. I just got the uzb1 and I wanted to update the firmware before I started to use it. So I installed the z-way-server-Windows-v2.3.3 but i could not do much, I was able to update the bootloader to to 40-.-,-.- (I dont remember exactly). But it did not show any firmware updates.
I tried to change the COM from 3 to 4, and tried to open up ports. I am not sure what I am doing wrong, would love some help.
Here is the log, I restarted the pc with a clean install of the server and I clicked the Open Updater where the connection in denied. And i cannot see any firmware updates in the expert mode either. Also tried to update and install some apps but it said it failed.
Documents.zip
(61.56 KiB) Downloaded 14 times
vafen
Re: Unable to update firmware / install apps / update apps
Post by vafen » 19 Dec 2018 00:19
Allright, I went ahead and set up Ubuntu as i understand the windows version is not supported anymore. I installed the z-way-server-Ubuntu-v2.3.8-rc5 since others have stated it might work.
Progress was made as I am now able to see the firmware updates, but after pressing the upgrade button I get the message
Unable to update data. /ZWave.zway/ZMEFirmwareUpgrade
There is no activity in the terminal after running the update. Only the background noise scanner is running at the moment.
Currently the controller info give me this:
bootloaderCRC: 40196 (21:58)
firmwareCRC: 17009 (21:58)
Application version	0.0
SDK version	6.71.01
And this is the one I am trying to upgrade to
2017-10-05 5.25 5.27 Update from 5.25 to 5.27 2CH firmware for EU/US/RU/IN/CN/ANZ/BR
Post by PoltoS » 11 Feb 2019 05:49
Looks like it was not able to fetch the file. Curl problems?
