Climate Control
Arek
Climate Control
Post by Arek » 10 Jan 2019 20:15
I have few Eurotronics Spirit TRVs and I'm using Climate Control app. I've got two questions/problems:
1. I have set for eg. two periods 7:00-22:00 -> 20 C; 22:00-7:00 -> 18 C; comfort temp. 20 C; saving temp. 19 C; fallback temp. -> saving
There is 22:00 on clock and this is what app does:
It happens in every trv. I assume it goes to saving temp. for one minute but why?
I tried to change to 6:59-22:00 / 21:59-7:00 but then happens crazy things
EDIT
I look at code and it is adding/deduct one minute form time when end=start/start=end, I think that it is some kind of protection
2. When I click "frost protection" I get back:
I think that this a problem that Spirit trv works in range 8-28 C and app try to set 6 C... Is it possible to change it?
EDIT
also in code there is frost protection = 6
Arek
Re: Climate Control
Post by Arek » 14 Jan 2019 10:32
It was working few days without "bigger problems" (beside mentioned above) but...in night from sunday/monday it set on every trv 19 degrees (fallback temp.) at 00:14 (?) and Climate Control app claim that this is what I scheduled (it is programmed 18 degrees from 22:00 to 7:00).
ehhh I bought RaZberry becouse I wanted to control radiators but I see that now I have more problems then using an "analog" thermostat and one main valve...
Arek
Re: Climate Control
Post by Arek » 06 Feb 2019 22:15
I notice one thing... I have set different times for each TRV. For eg. Room1: 7.00-22.00; Room2: 7.01-22.01, Room3 7.02-22.02 etc etc before all TRVs was set at 22:00 and many times it was something like it: set 19C, one minute later 20C, one minute later 19C, few minutes later 20C and it stay at 20C (according to schedule it should be 19C):| and now almost everything is working properly.
