UZB1 No Firmware Updates shown in Network -> Controller Info
mcmxb
Post by mcmxb »
I got a problem with updating my UZB1 Stick to the latest Firmware.
My UZB1 is shown as Static Controller with
SDK Version: 6.51.09
Serial API Version: 05.07
Now i want to update Firmware but when i click "Firmware Update" Button, there are no Updates available.
It says "Your stick uses the latest firmware".
Im on v3.0.0-rc23, same problem accured on another Pi with 2.3.8 running on it.
Can somebody help me getting my UZB1 up to date?!
Re: UZB1 No Firmware Updates shown in Network -> Controller Info
The newer fw was disabled recently. We will re-enable it back soon
mcmxb
Post by mcmxb »
How long do i have to wait?
I guess, i need the Update in order to pair the new Fibaro Roller Shutter v3 (FGR-223).
Or is this a wrong assumption?
petergebruers
Post by petergebruers »
Running Z-Way 2.3.8 on an oragangepi trying to update UZB1 I get this:
"2017-07-07 5.25 Update bootloader for 5.25 to 40196"
Then when I click Upgrade:
"Unable to update data. /ZWave.zway/ZMEBootloaderUpgrade"
Is this a symptom of what @poltos said: "The newer fw was disabled recently. We will re-enable it back soon", or is it something else?
@mcmxb: no, the UZB firmware is not related to the support of the roller shutter
petergebruers: no, should work if shows up in the UI
petergebruers
@PoltoS Thanks. I have replaced the O/S running on my orangepizero, which was based on ubuntu xenial, by this newer version: "Armbian_5.75_Orangepizero_Debian_stretch_next_4.19.20". Then reinstalled Z-Way... And then I was able to update the bootloader of my UZB1, good!
So now it has "05.26" with new bootloader, and Firmware update displays "Your stick uses the latest firmware", so I guess that is to be expected and now I have to wait for you to publish "05.32" again?
hunnypuppy
Post by hunnypuppy »
I had a similar experience and the issue was using Ubuntu 18.10 since it shipped with CURL4 where as z-way-server requires CURL3 to do a firmware update. Solution was to use Ubuntu 16.04
roquej
Post by roquej »
Currently on 5.07 and want to upgrade to the latest firmware. However, z-wave tells me the UZB1 is at the latest version. Is this due to the raspberry version or that the firmware upgrades were pulled?
Thanks,
JP
make sure to have v3.0.x and enter token "all"
