Expert UI: language, timing info, security
platypus
Post by platypus » 05 May 2019 18:27
I’ve got some questions about the Expert UI:
1. language
When I change the language (Settings- --> Language) it doesn’t remember this setting at my next login. It’s always English again. Is it a bug?
2. timing info
Under network --> timing info the legend says:
black: “Controller was not able to reach the given node with 3 attempts and tried a different route that finally worked“
What does different route mean? I only have battery powered devices which can’t act as repeaters. The packet sniffer also shows that no hops are used.
Red: “The communication finally failed after some re-routing attempts”
The sensor’s data sent at wakeup was completely received by the controller. How did it determine that the communication has failed?
3. security
Under device --> type info I see orange open lock symbols of Z-Wave Plus devices. What does that mean?
4. Controller in Lifeline Association
Under configuration --> association there is a red warning sign with an exclamation mark next to the controller. Is something wrong with it? And sometimes it’s named (#1.0) Z-Way and sometimes (#1) Z-Way.
enbemokel
Re: Expert UI: language, timing info, security
Post by enbemokel » 06 May 2019 16:42
1. never tried ;-)
2. I think you should ignore it if you don´t have a route/repeater node in your network
3. This product was not included with security, sometimes there is different way to include secure. E.g.: press 2 times including button and not 1 time.
Also, it may not support security, even it´s zway plus
4. This is normal from my point of view.
platypus
Post by platypus » 08 May 2019 20:24
3.
Regarding my Aeotec Range Extender 6 you’re right. I had to push the button twice. Now it shows a green lock symbol too. But the manual of the Popp mold detectors, which support security v2, only names one way for inclusion: pushing the tamper button three times and it should automatically work in a secure mode if the central supports security. I’ll ask the manufacturer about that.
Post by PoltoS » 09 May 2019 16:17
1. will check
2. this is a general message. if you have no rotes, just direct was tried
3. S0 is yellow, S2 is green, non securoty is red
4. This is legacy icon we have to remove once ;)
platypus
Post by platypus » 13 May 2019 22:18
2. This means that the packets’ runtime is the only reliable information one can get from this page? Then I’d suggest to remove these colours and legend text because it seems misleading to me. The communication didn't fail and no routing was possible.
3. According to their manufacturer these sensors POPE701202 do support S2 security. But only S0 was applied during inclusion. What might have gone wrong?
Post by PoltoS » 19 May 2019 15:36
2. The important is red VS green/black and the actual number to check delays
3. If you are on v2.3.8, it does not support S2. The v3.0,0 does
platypus
Post by platypus » 07 Sep 2019 21:20
3.:
Now that z-way v3.0.0 is out I tried again to add a Popp mold detector POPE701202. The device type info page now shows “S2 Unauthenticated“ and two lock symbols, one green and one grey. I assume that two green lock symbols will represent “S2 Authenticated” status. How can I get that? A PIN an a QR code are printed on these sensors but how can I enter the PIN in z-way during inclusion? There was no form, no window to put that in.
Post by PoltoS » 08 Sep 2019 13:47
Only in Expert UI you can do this. And only if the device supports it. Please try and it will show all security levels the device requests for
platypus
Post by platypus » 08 Sep 2019 16:35
When I include the device using the Expert UI a dialog comes up that asks for the security level but only S2 Unauthenticated can be selected. Then a long key shows up whose first five numbers match the PIN printed on the device and I can confirm that.
I read again in the device‘s manual and it says „The device supports the Security S2 framework with unauthenticated network keys.“.
Conclusion: A PIN printed on a device does not necessarily mean it supports S2 Authenticated. That was what confused me at first
Post by PoltoS » 17 Sep 2019 00:50
Correct, one can print the PIN to still allow you to verify it
