Hi
really like the new update except for some minor problems.
1) Hue App
I am using v1.1 of Tim Autons Hue app directly from Github (https://github.com/timauton/Hue)
Since upgrading to 3.1.0 only 3 lights are registered in zway anymore. These 3 lights are listed first in my hue app. There are 17 other lights, which are not usable anymore in zway.
i tried reinitializing, restarting the hue hub, restoring a backup and restarting zway.
2) Trap events from remotes and sensors
This app does not work since upgrading from 2.3.8 to 3.0.6
Maybe other people have the same problems or some solutions with these apps?
Another optical problem, when im checking some checkboxes in the options, i dont see the cross symbol.
for example: one of the boxes is checked, they look slightly different even without the cross, like in the picture attached
3.1.0 minor problems with some apps
- checkbox.PNG (2.34 KiB) Viewed 5447 times
Re: 3.1.0 minor problems with some apps
I also have problems with rendering marks at 3.1.0 @ latest Chrome
IE11 shows marks correctlyRe: 3.1.0 minor problems with some apps
For me the icons gone missing from the "desktop" UI version.
Update: generically the skins are really messed up
- apps.JPG (41.31 KiB) Viewed 5402 times
- menu.JPG (29.21 KiB) Viewed 5402 times
- header.JPG (13.48 KiB) Viewed 5402 times
You are right, we have updated icons and skins were not revised. We will make that asap
Indeed, check boxes looks to have issues. Will check it.
As for trap events, new security policy do not allow this anymore according to Z-Wave Spec. We will check how to fix it
Thanks for looking into this, trap events seems much faster than using the scene controller!
anyone using the 1.1 hue app and having the same problem?
I cant find the old 2.3.8 firmware anymore. Does someone have a link to the image?
I need to revert back, the wife acceptance factor is at 0. Hue app and trap events from remotes and sensors do no work anymore and that means i cant use half of the lights in my house.
Is there a way to run 2.3.8 on buster? I got a Rpi 4 and need to use at least buster, it wont boot on stretch
No, sorry. We support new s/w on new platforms.
