Has oneone had an issue with their UZB frequency?
I'm from Australia (921Mhz). Just transferred my UZB from Windows PC to Rasperry and found (among other issues) that now I'm allowed to choose between EU, RU, IN and CN frequencies only.
What the?
UZB frequency
UZB frequency
- Frequecny.png (38.95 KiB) Viewed 14194 times
Re: UZB frequency
Found this topic
https://forum.z-wave.me/viewtopic.php?f ... ncy#p88690
Apparently, if you need to change your region use this command:
http://IP:8083/JS/Run/zway.ZMEFreqChange(XXX)
where
IP - your IP
XXX - your region
Regarding region. It is not straightforward. I it described in their manual:
Function Class ZMEFreqChange
Syntax: ZMEFreqChange(freq, successCallback = NULL, failureCallback = NULL)
Description: Change Z-Wave.Me Z-Stick 4 frequency. This function is specific for Z-Wave.Me hardware
Parameter freq: 0x01 RU. 0x02 IN. 0x03 US. 0x04 ANZ. 0x05 HK. 0x06 CN. 0x07 JP. 0x08 KR. 0x09 IL. 0x0A
MY. 0xFF request current frequency (ZME firmwares prior to 5.03 don’t support this feature)
For me (Australian region) command looked like:
http://localhost:8083/JS/Run/zway.ZMEFreqChange(4)
Important would be to say that for some reason it may compain that you need to login first. Well, try use this command from the same browser window/tab where you already logged into zway. Goodluck.
where
IP - your IP
XXX - your region
Re: UZB frequency
THANK YOU!!!! I wish the instructions were more accessible.
I was able to change my UZB to US region frequency with http://localhost:8083/JS/Run/zway.ZMEFreqChange(3)
- for anyone else read this, it seems as if the command was successful, return is simply "null".
Oddly enough Z-Way's display changed once I updated the dongle. How helpful. to
Re: UZB frequency
Turning Debug mode on the Network > Controller Info tab would allow to see all buttons for the frequency change. By default only similar frequencies are show to prevent people trying US on a EU antenna and vice versa
