How to find available hub IP address via API
hi, anybody knows here how to find available z-wave.me hub direct ip address via API or some other method ?
Re: How to find available hub IP address via API
Do you mean the local IP? /ZAutomation/api/v1/system/first-access should provide it
I mean when I Navigate to https://find.z-wave.me/zboxweb/ then it the bottom I can see the Direct connect to Z-Way:
192.168.0.51 192.168.115.1
like this so how we can this ip address without opening this website. I mean how to find with API or some other method to scan the z-wave.me hub IP addresses.
You can use local ip address
don't forget to add the port 8083
192.168.0.51:8083
That should work as a local connection.
192.168.0.51:8083
Raspi 4 - (Buster - 32 Bit) Zwave Version 4.1.1, Raz 7 Pro, Serial API Version: 07.38
I know this is local ip address but how we can find it without opening the https://find.z-wave.me/zboxweb/ site .
The question you asked for has been answered !
You might want to elaborate on what you really mean.
Be Lucky !
Micky
Be Lucky !
Micky
I want that how we can find the ip. Addresses without going to the website ?
Windows Cmd prompt. IPCONFIG
Linux type IFCONFIG
It is your own IP address, no need to look further to find it.
You cant mean that ?
Try again !
Linux type IFCONFIG
Try again !
If it is just an alternative way to find a local device IP address then you can see your list of devices in your router settings.saqib6161 wrote: ↑09 Mar 2022 21:24I know this is local ip address but how we can find it without opening the https://find.z-wave.me/zboxweb/ site .
Rpi4 2Gb, Z-Way 3.2.2, UZB 5.39
Maybe you ask for a dyndns service, then you can open a port in your router and connect from anywhere.
