HTTP Device with auth Bearer Token
MadMAX
Post by MadMAX »
i am trying to create a device which get its values from Home Assistant.
So I tried to use the HTTP Device and Virtual Device (Javascript) but i just not skilled enough to get the value via the RESTful API of Home Assistant.
The URL i like to read is
http://192.168.111.17:8123/api/states/sensor.temperature
but it need the Bearer token in the header of the request to access.
headers: {
      'Authorization': 'Bearer <token>'
Who would the URL or the code (Javascript) would look like to get access?
Thanks in advance.
Regards Max
Re: HTTP Device with auth Bearer Token
You can use Code Device with http.request.
Please check this manual: https://z-wave.me/manual/z-way/JavaScri ... 0000000000
MadMAX
Post by MadMAX »
Do you mean virtual device (JS)? i dont have an applikation with the name code device!
Yes, Virtual Device. As I remember, it is called CodeDevice internally
flabbyburnish
Post by flabbyburnish »
Many codes used. Is there any method to differentiate?
Please clarify your question
cashewsslate
Contact:
Post by cashewsslate »
What happens happy wheelsif you use the token of all?
Do you mean not at all? You will get no data. If you add an anonymous user or enable the Z-Wave/Zigbee API with no authentication, you can connect without the token. But this is not recommended for production unless you know what you are doing
