Zigbee USB ?
Re: Zigbee USB ?
I did it now. Thanks for the hint.
I have hoped that the forum also can help me.
Especially because also someone from the Z-Wave.me Team is also active here.
I guess I was wrong then.
Sorry, my fault.
Sorry, my fault.
Re: Zigbee USB ?
Have you tried with Z-Way at first?
My device is recognized at ttyUSB0 (Z-Wave) / ttyUSB1 (Zigbee).
And it is listening for Zigbee devices.
Michael
Michael
Re: Zigbee USB ?
Yes I did.
It simple doesn’t work?!
After not having success with Z-Way. I tried ZHA and ZigBee2MQTT but also without having success.
Re: Zigbee USB ?
Try at Raspberry console:
there should be something like that:
Have you something else connected at USB ports?
And - what is your Z-Way version?
dmesg| grep tty
[ 11.835361] usb 1-1.4: cp210x converter now attached to ttyUSB0
[ 11.844992] usb 1-1.4: cp210x converter now attached to ttyUSB1
Re: Zigbee USB ?
I'm running Home Assistant OS on Raspberry Pi4
No other USB Devices are attached.
And the Z-Wave.me Addon, Z-Way Server v4.1.0
Z-Wave ist working fine, but ZigBee not!
- Bildschirmfoto 2024-04-20 um 21.31.13.png (50.36 KiB) Viewed 374 times
Re: Zigbee USB ?
try to make an Z-Way update, I use 4.1.2 ...
Michael
Michael
Re: Zigbee USB ?
I have installed the Z-Way server on a second Pi4
Now v4.1.2-6-g701b28b3
Zigbee via Z-Way is now Running. But still not with ZigBee2MQTT!
ZigBee2MQTT 1.36.1 commit: ffc2ff1
Zigbee2MQTT configuration
With other ZigBee Adapter like Conbee II or Aeotec Zi-Stick ZigBee2MQTT works fine.
I tried to use the Z-Wave.Me Tools to get at minimum a info about the ZigBee Firmware.
But it always end up with tis error?!
@PoltoS can you confirm that the Z-Station should also work with ZigBee2MQTT?
serial:
port: /dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_012B7AE7-if01-port0
adapter: ezsp
baudrate: 115200
rtscts: true
pi@z-way:~/z-station/zme_zigbee $ sudo ./zme_zigbee info -d /dev/ttyUSB1
./zme_zigbee: 1: cannot create u%@@��info -d /dev/ttyUSB18
@@@@@h��@�@@@PP: Directory nonexistent
./zme_zigbee: 2: Syntax error: Unterminated quoted string
Re: Zigbee USB ?
What add-on do you mean?
I'm using HA docker version and the Z-Way (actual 4.12) integration since a long time (after was published) - but in this time only for Z-Wave devices...
About the HAOS add-on didn't know...
Re: Zigbee USB ?
@PoltoS Thanks for your Quick response on GitHub.
Where I get the firmware from? And how to performe the firmware update? Unfortunately the Z-Wave.Me Tools doesn’t work for me. Not on windows nor on Linux?!
Is there a clear instructions somewhere?
Or can the firmware update also be done via Z-Way Server?
Thanks in advance.
Thanks in advance.
