Does razberry work with the schlage locks? I purchased one and can't seem to get it to enroll. For reference it is model BE469NXCEN625 found here:
http://www.amazon.com/gp/product/B00AGK ... UTF8&psc=1
Razberry & Z-Way -- Support Door Locks?
It somewhat works
I struggled with it for some time. Finally got it working (somewhat…).I am not sure what fixed it at the end but here are the things to check/do:1. Check the batteries are 1.5 and not 1.2 (not sure if it makes a difference though)2. Follow this instructions for the Schlage side (on the lock): http://wiki.micasaverde.com/index.php/S ... eshootingI did this in the expert mode.The question I have is how to manage/change PINs for the lock via web interface. Is it something not supported or just not implemented in the included RaZberry’s web interface?
Just not implemented in the
Just not implemented in the UI. Press Expert button, go to Expert Commands tab and use UserCode Set to set codes.
