I just installed the Razberry zwave module on my Pi3, I followed the installation instructions and everything went smoothly, however when i go to find.zwave.me, below the login screen it finds my razberry but when I click on it or manual type in the ip adress for access to the GUI, I just get an immidiate response that the connection is refused.
I tried reinstalling the Pi and Zwave but this does not work.
Need help, anyone got an idea what the problem could be?
Cant access Razberry IP and GUI on razbarry zway
Re: Cant access Razberry IP and GUI on razbarry zway
What is your RaspberryPi OS version? Jessie or stretch?
Hi I just found out it is stretch, how do I downgrade to jessie?
you can install that additional lib like this:
wget http://mirrordirector.raspbian.org/rasp ... _armhf.deb
sudo dpkg -i libssl1.0.0_1.0.1t-1+deb8u6_armhf.deb
it will have some side effects of that some of ZWAVE modules will use 1.0 version the other standard library will use 1.0.2. I am testing it and it seems working for now.
Hopefully, next update of Zwave.me server will include correct build for Stretch.
Thanks for the help, it works now
I have to say thank you as well vlad!
Does someone know, if it is possible somehow to force z-way-server to only use the old libcrypto.so.1.0.0 library instead of both the old libcrypto.so.1.0.0 and the new libcrypto.so.1.0.2 at the same time when running on stretch?
The z-way-server is basically still running after I upgraded my RPI from jessie to stretch, but unfortunately now it terminates every few hours with a SIGSEGV in libcrypto.so.1.0.2. Before the upgrade it ran stable for weeks. I guess this happens because of the mix of the two libraries. It seems to always happen when messages from a security enabled z-way device are processed.
Or is there something else I can do to prevent those crashes?
Because I have a lot of other things running on my RPI I don't want to downgrade it to jessie again only because of this.
Unfortunately, until Z-Way will be compiled with new 1.0.2 library it doomed to run like this. Z-Way itself is referencing 1.0.0 but all other components from Stretch are using 1.0.2.
I have some side effects (like update console always shows an error - this has something to do with SSL stuff) but not that serious like crashing after few hours.
I was hopping that 2.3.6 version will have variant compiled for Stretch but looks like not dice so far...
I put the z-way-server now into an LXC container with a Debian Jessie file system that runs on my Debian Stretch RPi. This is not a very simple solution, but at least it seems to work for me again properly now until we hopefully get a better solution. (Probably running it using chroot on a Jessie file system would also work, but I did not try it.)
Hi!
Does the problem still exist?
Installation of the additional lib fails (NOT FOUND).
