Does this main.js work-around also apply for version 1.3?
If so I will update the OpenRemote-Razberry integration document according to these instructions
New version of RaZberry is released
When I click on 'Device
When I click on 'Device configuration' -> 'GreenWave' I also get the 'method_guilnit: values[] size differs from number of parameters' error dialog.
The same error message is displayed for all my GreenWave 1-port and 6-port switches.
Thanks for your quick replay.
PoltoS:
Thanks for your quick replay. First of all, placing line executeFile(automationRoot + "/" + "openremote.js"); at the beginning of main.js doesn’t' solve the problem. I also tied with executeFile(config.basePath+"/openremote.js"); but also without success.
And Force interview doesn't solve Danfoss error.
Pieter:
Have you already tested the new version and if this works for you?
Regards,
Nejc
Pieter:
Regards,
Nejc
I am working on it right now.
I am working on it right now. I could not start testing RC1.4 before I solved the last issue with the new RaZ-OR Somfy Sunshades function.
I did move the two lines
executeFile(automationRoot + "/" + "my_openremote.js");
to the very top of main.js in version 1.3. That stopped working. So it confirms your findings.
I have just contacted them directly on our problems
Pieter
Pieter
Solved it for v1.3
I have it working in v 1.3
The openremote.js line should go just before the first function, because it does need the "automationRoot" declaration:
---------------snippet------
var automationRoot = "automation/";
var configFile = automationRoot + "config.js";
var moduleFolder = automationRoot + "modules/";
function startAutomation() {
------------end snippet-----------
I am curious if that works for RC 1.4
Solved it for v1.4
I solved it for 1.4 version. Just put line executeFile(config.basePath+"/openremote.js"); in section
//--- Load Automation subsystem classes
executeFile(config.classesPath+"/AutomationController.js");
executeFile(config.classesPath+"/AutomationModule.js");
executeFile(config.classesPath+"/VirtualDevice.js");
in main.js file.
Regards,
Nejc
in main.js file.
Regards,
Nejc
Set Thermostat Danfoss
About Danfoss error. I found that the new version doesn’t support ThermostatMode class. Now I can't set temperature on Thermostat. How it can be done? Is there any new manual for new version?
I understand it will be
I understand it will be different in the final 1.4 release. As soon as I hear their solution I will publish it in the OpenRemote RaZ-OR thread http://www.openremote.org/display/forum ... h+Razberry
Afaik Danfoss never supported
Afaik Danfoss never supported the ThermostatMode class. As a mater of fact it is always in "heat mode".
COMMAND_CLASS_THERMOSTAT_SETPOINT should do for the thermostat setting. Unfortunately I can't check this, as I abandoned the horrible Danfoss Living Connect.
Update September ???
when will the update will be ready?
