Sorry, server has not completely started yet...
Dave
Any Update?
Post by Dave » 09 Mar 2013 15:56
Could you please tell me when this problem will be sorted out?
We have fixed this. Will come
Post by PoltoS » 09 Mar 2013 15:56
We have fixed this. Will come in next release (which will contain a lot of fixes).
Dave
Update Release
Is the next release due soon?
It finished and is in tests.
McD
same problem after adding Fibaro
Post by McD » 09 Mar 2013 15:56
I am experiencing the same problems after adding a Fibaro Relay Switch to my installation.
Safari works fine, but Firefox, Chrome will show me the message.
Please update Z-Way (by
Please update Z-Way (by running same command a for installation). This is fixed now (workaround for a bug in JS engine in browsers)
Dave
What Have You Done!!!
I have just run the update, as you suggested, and I now find the Razberry server will now not even start.
What have you done?
What do you see in the log?
Dave
Fresh Install
I have no idea what was in the log as I have had to reformat the SD card and install a fresh copy of Rasbian.
With the fresh start I have now got the Razberry server back running.
I think in future I will try new updates on a backup SD card before I over write my working copy.
If it is not running, you
If it is not running, you should see some problem in logs. Do you see the z-way-server process in top/ps?
